1 members (55shaker),
117
Mod | | | Forums66 Topics128,088 Posts1,056,416 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | I would like to know where to attach the bracket for the crankcase draft tube. As some of you may know, I have been working on my restoration project for some time and the truck has been disassembled for many years. I should have done a better job of taking pictures. I would like for someone to post a picture of the draft tube bracket on their truck engine so I can see the proper location and method of attachment.
Thanks in advance.
John | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Try looking in the truck manual for a picture of the eng. side of the draft tube, it should show where its bolted to, I think its the oil pan. root | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Root,
The manual does not show this and have not been successful with a a search of the internet. Hence, my request fod someone to post a picture
Johm | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | John, I also could not find an illustration in in Shop Manual or Operator's Manual, but there might be an illustration in a Factory Assembly Manual for your "generation" engine. Here is a 1954 235 engine' road draft tube. You can almost see the metal "strap" around the tube and where it is attached to the block with a small bolt. The earlier 235/216 engines' road draft tube was, I think, attached differently. I think the shape of the road draft tube changed when the front motor mounts changed (late 1950s?). Pre '68 Dave would be a source of knowledge of the different road draft tubes, and where they attached to the block? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ....don't have a pic either but depending on the model year some did bolt to the bottom of the pan of which I'm fairly sure. If you do not want to use a draft tube Deve has a nice article on his site how to use a PVC vale made from freeze plug/grommet and PVC valve. I did it on my 261 engine. Just an idea..... | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Depending on year of block and tube used the mounting position changed. In Tim's link you can see one of the mounting positions. Most blocks also have another mounting option about half way between the distributor and dip stick, just above the pan rail. In this LINK you can see where it is (there is a bolt in the hole).
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | Thank you all. All of your responses helped to confirm my thoughts as to the location of the clamp. I frequently visit Deve's website, especially while getting the motor reassembled. There will be many more questions as I continue with my frame-off project. I am always appreciative of the Stovebolt's vast experience. | | |
