0 members (),
89
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | No response in the lounge so I will try here. Can anyone tell me if there is one or two seals for the windshield of my 38 panel delivery. The windshield now has a flat rubber gasket sandwiched between the frame and moves out with the glass. Is there another gasket or seal on the cab window frame? | | | | | Joined: Feb 2000 Posts: 5,199 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,199 | I think your panel is the same as my 37 truck. It has just one seal. It has a lip that snaps in the frame and about a 1" lip that seals to the cab area. It goes around the windshield frame. The glass is set in tape in the frame. As you open the windsield the seal moves to. You can buy new seal for $20 or less. From what I have read here, they don't seal real good. You may have to add some type of foam seal to the inside of sealing area. Joe | | | | | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | Thanks, it's hard to find info on some of these things. Some of it is for pickups and some for cars but not much on the panel deliverys | | |
