8 members (walter74, mvigo, Forty9, Shaffer's1950, Rusted Nut, mick53, Wally / Montana, klhansen), 114 guests, and 2 robots.
Topics128,049
Posts1,055,740
#115316 11/18/2003 12:26 PM
Junior Member
Junior Member
One of my hinges needs a new hinge pivot bolt. Has anyone replaced one before. It is oversized to accommodate a worn hole. I bought one to rebuild my old hinge. How did you do it? Thanks!
Richie West
#115317 11/18/2003 4:08 PM
Depending on the type of replacement hinge pins/bushings you have (or you buy), this might be of help:
http://www.classictruckshop.com/door_hinge.asp
Tim
#115318 11/18/2003 6:29 PM
I don't know about your specific hinges but usually hinge pins are used with bushings. The bushings can be punched out and replaced with new ones. That way your hinge isn't toast when things wear. I think you can get standard hinge pin/bushing repair kits for a couple of bucks at your local car parts store. I have seen and used them in the red "Help!" packages.
#115319 11/18/2003 7:27 PM
I also ordered the "oversized" hinge pins/bushings, but when I got them I discovered they were too large. Most of the slop was due to worn bushings. I went to NAPA with the disassembled hinges and found a set of metric pins/bushings that were a press fit.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#115320 11/19/2003 8:32 AM
What year is the truck?
#115321 11/19/2003 6:15 PM
1950 Chevy 1/2 ton
