| | | Forums66 Topics128,072 Posts1,055,903 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 36 Junior Member | | Junior Member Joined: Oct 2003 Posts: 36 | One of my hinges needs a new hinge pivot bolt. Has anyone replaced one before. It is oversized to accommodate a worn hole. I bought one to rebuild my old hinge. How did you do it? Thanks!
Richie West
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Depending on the type of replacement hinge pins/bushings you have (or you buy), this might be of help: http://www.classictruckshop.com/door_hinge.asp Tim | | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I don't know about your specific hinges but usually hinge pins are used with bushings. The bushings can be punched out and replaced with new ones. That way your hinge isn't toast when things wear. I think you can get standard hinge pin/bushing repair kits for a couple of bucks at your local car parts store. I have seen and used them in the red "Help!" packages. | | | | | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I also ordered the "oversized" hinge pins/bushings, but when I got them I discovered they were too large. Most of the slop was due to worn bushings. I went to NAPA with the disassembled hinges and found a set of metric pins/bushings that were a press fit. | | | | | Joined: Sep 2003 Posts: 55 Member | | Member Joined: Sep 2003 Posts: 55 | | | | | | Joined: Mar 2001 Posts: 15 Member | | Member Joined: Mar 2001 Posts: 15 | | | |
