1 members (Gray_Ghost), 65 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
1 Offline
The brass division block (I think that's what it's called) that connects the end of the master cylinder to the break lines became stripped. I can't find where to purchase these. Does anyone know where to find one? It's for a '54 1 Ton.
1942 BK 1/2 Ton Pickup
1954 3800 1 Ton Pickup
1 Offline
After doing some research I realized that this may be two different parts, so I suppose I'm just searching for a master cylinder division block. I found a lot of rear wheel cylinder blocks, would that work?
Riding in the Passing Lane
Possibly. Speedway has a lot of various fittings.
1972 Chevy c10 Cheyenne Super
Try searching for an "inverted flare banjo fitting". The lines running to the front and rear from the master cylinder are usually 1/4" OD tubing, and the inverted flare T fittings at the front crossmember and the rear end housing will probably have one 1/4" inverted flare socket and two 3/16" tube sockets. It's possible the master cylinder will have two banjo fittings stacked together with a copper seal washer between them, with a long banjo bolt holding them to the master cylinder outlet port.
1 Offline
Hi, does anyone possibly have a photo of the back of their master cylinder? I haven't really been able to find this piece I need and I want to see if this was changed over time. I would think, since it is connected to the master cylinder it would be a piece that most people would carry.
Chevs of the 40's has something similar, just smaller than I need. I just can't find this anywhere.
https://www.chevsofthe40s.com/detai...Junction_Block_Left_Front_At_Master.html
I keep these block from scrapped trucks. send me a picture of yours and I'll see what I have
[email protected]
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
1 Offline
I was able to find the piece from an odd auto parts store. Thanks for the help.
