5 members (DoubleB, EchoBravoSierra, frogfarmer, TooMany2count, Achipmunk), 55 guests, and 1 robot.
Topics128,090
Posts1,056,024
Members48,432
1 Offline
The brass division block (I think that's what it's called) that connects the end of the master cylinder to the break lines became stripped. I can't find where to purchase these. Does anyone know where to find one? It's for a '54 1 Ton.
1942 BK 1/2 Ton Pickup
1954 3800 1 Ton Pickup
1 Offline
After doing some research I realized that this may be two different parts, so I suppose I'm just searching for a master cylinder division block. I found a lot of rear wheel cylinder blocks, would that work?
Riding in the Passing Lane
Possibly. Speedway has a lot of various fittings.
1972 Chevy c10 Cheyenne Super
H Online: Content
Try searching for an "inverted flare banjo fitting". The lines running to the front and rear from the master cylinder are usually 1/4" OD tubing, and the inverted flare T fittings at the front crossmember and the rear end housing will probably have one 1/4" inverted flare socket and two 3/16" tube sockets. It's possible the master cylinder will have two banjo fittings stacked together with a copper seal washer between them, with a long banjo bolt holding them to the master cylinder outlet port.
1 Offline
Hi, does anyone possibly have a photo of the back of their master cylinder? I haven't really been able to find this piece I need and I want to see if this was changed over time. I would think, since it is connected to the master cylinder it would be a piece that most people would carry.
Chevs of the 40's has something similar, just smaller than I need. I just can't find this anywhere.
https://www.chevsofthe40s.com/detai...Junction_Block_Left_Front_At_Master.html
I keep these block from scrapped trucks. send me a picture of yours and I'll see what I have
[email protected]
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
1 Offline
I was able to find the piece from an odd auto parts store. Thanks for the help.
