| | | Forums66 Topics128,068 Posts1,055,881 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | I,m in the process of installing dual exhaust with glasspacks on my 49 3600 with 261 engine. Is there any advantage to using an X pipe in the system as far as torque, horsepower or sound/ Dave V | | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | On the six cylinder, about all you will get is mellowed sound. The firing order is not right for the x-pipe do what it does to the V-8's. It will take out some of the harshness of the six cylinder exhaust notes, so that it's an advantage I guess. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | Joining the exhaust pipes in any way will reduce or eliminate the scavenging effect of having a split manifold. The front/rear alternating of exhaust pulses is really the only reason for having duals on an inline six, other than the eye candy appeal of the system. Ditto for dual or triple carbs! Jerry
| | | | | Joined: Sep 2012 Posts: 222 'Bolter | | 'Bolter Joined: Sep 2012 Posts: 222 | Thanks for the replies. I guess there is no need for it then. DaveV | | |
