8 members (Wickedbass, NJC, GRNHydra, Gone, hdgeren, Otto Skorzeny, rfs56trk, Peggy M), 68 guests, and 2 robots.
Topics128,023
Posts1,055,370
Members48,420
#114990 10/28/2002 10:00 PM
I am going to be replacing the cab corners on my 1957 Chevrolet 3100. I was wondering if anyone had any experiance, info, dumb things not to do, etc.
#114991 10/29/2002 4:08 AM
Junior Member
Junior Member
A few good tips are Not to cut the old cab corners off till you get the new ones. Incase you cut to high or something. eek Another good tip is to keep test fitting the new cab corner as you are cutting the old one off. Measure twice, cut once. smile Tack corners on first and make sure it's exactly where ya want it before ya start welding. Also let the metal cool as much as possible to avoid warping from too much heat.
*under construction* 1962 Chev truck: Bagged & bodydropped, shaved, custom made clear tailights & roll pan, custom made aluminum parts.
http://www.geocities.com/philswebsite2003/
#114992 10/29/2002 4:27 AM
I just did the job and I was supprised how easy it was.
check out my web site, I have a few pictures from this process. I did not weld the corners. I used a new product called Duramix and actually glued them in. My local Chevy dealer- body shop adviced me to go this route. They explained they barerly use the welder for non structual pieces.
Fritz Peyerl
Turner valley, Alberta
http://www.badmileage.com
