| | | Forums66 Topics128,266 Posts1,058,367 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Can't locate a connector that will fit onto the temp sender unit that fits my 1958 GMC 1/2ton truck. Not sure what the connector even is. Thanks in advance
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Danny, they have these at the local flaps. If I remember correctly on your model engine the threads are UNF and not NPT.
Here you go... I think this will answer our question's.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Number/1141519/Searchpage/3/Main/167950/Words/temperature+bushing/Search/true/Re:_Water_Temp_Gauge_Fitting_a.html#Post1141519
OOPS....your looking for electrical....sorry
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Am looking for the electrical connector that goes on the top.....
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Top of the sender look like a little hat?
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | It is part# 61-248985-1 at Ecklars website.Hard for me to describe
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
Denny G Sandwich, IL
