Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
8 members (Hotrod Lincoln, farmallb, Chip O, tclederman, Charles in CA, Otto Skorzeny, Stovebolt48, TooMany2count), 46 guests, and 0 robots.
Topics128,006
Posts1,055,272
Members48,418
#114984 05/22/2005 3:37 PM
I
I Offline
My son and I are working on a 57 Chevy Panel.
The front fenders are pretty badly rotted in the rear and the brow.
I have seen patch panels all over for about $30 each.
I have seen repro fenders for $200 (fiberglass), and $365 (steel).
Is it worth the time and materials to fix the originals or should I buy new ones>
If new... glass or steel?
IRWIPI 2005 Peoples Choice
Inky,
"It's not that I haven't done IT... It's that I haven't done IT yet."
'48 1-1/2 ton Dump
'57 Chevy Panel
'59 Chevy 2 ton Dump
#114985 05/22/2005 5:13 PM
if yer handy w/ a torch [or have someone who is] the patch panels can work ok, but if they're pretty rough you won't save any $$ over the repro steel fenders, which are supposed to be quite good - the glas ones can work if the truck will be exposed to further rust causing conditions, cuz the design of the TF fenders will continue to invite rust no matter what ya do
yer time and materials will prolly be more needed for the quarters w/ a panel - and the bottoms of the back doors grin
#114986 05/22/2005 5:18 PM
My experiance with repro parts is not good, I would stick with repairing the old ones. It seems that 99% of repro parts need as much work as if you just fixed the old ones.
Brian
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
#114987 05/22/2005 10:19 PM
I
I Offline
The only rot is on the fenders and the front door posts. The quarters and doors are great.
Inky,
'48 1-1/2 ton Dump
'57 Chevy Panel
#114988 05/24/2005 6:40 AM
even if you took the fenders to a body man to have them pro. fixed theyed be better and cheaper than repos.
