7 members (55shaker, frogfarmer, Opelika Tom, Gray_Ghost, Hanks custodian, cmayna, TGP), 111 guests, and 3 robots.
Topics128,185
Posts1,057,203
Members48,465
I put 1973 GMC truck front end assembly under my 1965 Chevy truck.Has anyone else done this and how did it work out?
Every place that I've read about these conversions says it works great. You are now converted to 5 lug and disc brakes, right? You should use everything from the 1973. gear box, pitman arm, crosslink, spindles.
Unconventional Thinker
I haven't done the whole assembly, but I have done the conversion using the modern spindles, but using my old control arms. I've read that using the whole assembly works too. Mine is 8 lug, and I didn't know where to source a 3/4 ton front end, so I had to buy kits. I wish I'd known then what I know now, I could have save a ton of money.
Shane
Shane's Toys...
2007 Forester XT Limited (2nd Owner)
1991 Cherokee Laredo (2nd Owner)
1981 Chevy 3/4 Ton Fleetside 8,600 Camper Special (3rd Owner)
1965 Chevy 3/4 Ton Fleetside (3rd Owner)
I did it and worked well. You just have to change out your tie rods and ball joints for whatever year spindles you have and I took the steering linkage from the donor otherwise you have to use some tie rod adjuster sleeves. They are $50 bucks
On my 64' I used an 87' model, and it was a breeze. I now have disc brakes, power steering, and parts that are 20+ newer. Even managed to score the sway bar.
dj durant
More pix on Flickr
How the swap turn out?
Crusing in the Passing Lane
I did a 91 Suburban suspension/cross member swap on my 66 Suburban and it turned out great.
Currently cruising
in the Passing Lane
Rest in Peace
