8 members (DougH6100, Gdads51, Donf, Hanks custodian, FAST55, Gray_Ghost, Bill Hanlon, cmayna),
142
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,162 Posts1,056,950 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | I finally found a good hood for my 53 gmc fire truck but as I predicted, I ended up getting a whole truck. It's a 1954 450 series. Still a cool, good running truck that has a good 248 engine and the pto winch still works. Hood was dang near perfect. I do enjoy hunting down info on the different years and I never knew they had wipers on the top of the cabs on some. I put a picture on because I noticed there are not many similar in the gallery. I'm assuming the 55 1st series were similar in these sizes http://s1167.photobucket.com/user/t...0Uploads/image_zpskcaub1jk.jpeg.html?o=2 | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | My '54 630 has overhead wipers. Your 450 looks nice.
Ed
| | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | tri5, That '54 450 should have a 302 in it, unless it's been changed, & not a 248. 1954 was the first year that the wipers were above the windshield on AD/ND trucks, but only on 400 series, and larger trucks. You'll also notice that from 400 series up, the 54 models used the round park lights, & not the square park lights as the 350 series down use. | | | | | Joined: May 2005 Posts: 323 Shop Shark | | Shop Shark Joined: May 2005 Posts: 323 | Yea I was disappointed to see it had the 248 and the glovebox vin said it had the 302 but at least it runs good | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Too nice to part! Bet you're still looking for a hood!! | | |
