7 members (Goach2, Gdads51, Bill Hanlon, TexasA&M48Truck, 2-Ton, Southerntruck, NJC),
124
Mod | | | Forums66 Topics128,204 Posts1,057,302 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | I decided my 53 AD needed a clock. I know they did not offer a dash mounted clock so I just made a 53-54 car clock work. I found a 3 inch ID female to female exhaust PIPE connector to use as a housing. Welded two TABS to the inside. Cut it to MATCH the dash. It looks GOOD to ME
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I decided my 53 AD needed a clock. I know they did not offer a dash mounted clock so I just made a 53-54 car clock work. I found a 3 inch ID female to female exhaust PIPE connector to use as a housing. Welded two TABS to the inside. Cut it to MATCH the dash. It looks GOOD to ME Looks good.Nice job | | | | | Joined: May 2010 Posts: 19 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 19 | looks real nice, great job. | | | | | Joined: Nov 2012 Posts: 444 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 444 | That clock looks great. Today I put the 47 3800 dually AD on a trailer and towed her down to my welder buddy. I cut all the old panels away last weekend. I left him with new panels. I can't wait to get the phone call.....come and get it. Joe 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Finally got the correct speedometer cable housing that goes into the automatic trans on my panel. Finally, the leak is gone.
Hey Mike, darn good job on the clock housing. Beats the 400 or more some want for them!
It was suggested sometime ago we had a place to post these sort of ideas/developments. It sure would be nice. Did you make two?? One would like nice on the panel dash!
amtrackjoe, be sure and post pictures. | | | | | Joined: Dec 2014 Posts: 66 'Bolter | | 'Bolter Joined: Dec 2014 Posts: 66 | I like the air filter that you installed, could you share the modification details as to how you mounted it...thanks Hey Blanch - I had a standard oil bath filter housing base that was rusted thru in a few spots. So I cut the bottom out of it (somewhat oversize), keeping the center part with the stock pinch clamp that goes over the top of the stock carb. Now you basically have a 6" or so diameter disk. I cut off the "pipe" sort of sheet metal that sticks up into the upper assembly of the oil bath filter, the part with the stud the wing nut threads on to, there's no need for it anymore. Next I brazed the bottom of the Edelbrock filter to this "disk" with the pinch clamp. I brazed it in 4-5 spots around the inside perimeter. It was too thin for my welding skills, brazing was safer. I mixed up some JB Weld and applied a bead to the areas where there wasn't brazing, just to seal off any short cuts unfiltered air could take. Then I trimmed the extra material from the outside until it matched the Edelbrock base diameter. At that point the rest is cosmetic stuff, sanding, painting. Now you have a filter that mounts as an original would.
'59 Apache ‘21 Beta 390RS ‘18 BMW R1200RT '12 Ford Flex '13 Aprilia Tuono ‘11 Ducati Hypermotard Salisbury, MD
| | | | | Joined: Oct 2014 Posts: 13 New Guy | | New Guy Joined: Oct 2014 Posts: 13 | this weekend i replaced the door latch and window regulator. fought with installing the vent assembly for hours until I removed the back channel screws, which gave me the wiggle room needed to seat the glass into the front channel. Recently pulled the Harrison Fresh Air heater, pulled the core which was leaking and had a local shop re braze the core. This is a 53 3100 daily driver for my daughter. 1953 3100 5 Window 1959 American LaFrance | | | | | Joined: Dec 2012 Posts: 122 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 122 | Tossed a couple gallons of 'real' gasoline into my tank since inserting a debris strainer into the outlet valve; checked for leaks around the valve and fittings... nice and dry.
Got her restarted no problem and after idling for 10 or 15 minutes, it started flooding all of a sudden. Sheesh... | | | | | Joined: Oct 2015 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 27 | Installed the freshly delivered passenger side engine frame perch for the 292 in the 71 GMC. Masked / first coat of flat black on the grill..
(2) 1954 3100's / foster parent - SOLD 1955.1 3100 Resto in progress 1971 GMC 2500 Custom / foster parent 1951 M37 Lawn ornament 1949 3800 Panel Resto in progress 1959 GMC 100 LB Fleetside
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I know it's my own doing, but it has been flat out weird working on my truck and not getting filthy dirty the past few weeks. Tonight, I started removing all the bed wood bolts to remove the wood for paint. I was grabbing the frame, springs, cross sills, drive shaft, differential- whatever was there and I'm getting the truck dirty as opposed to vice versa... (and what is a safe cleaner to remove Al anti-seize?)
Maybe I just got hooked on fast orange or something & haven't used it for a while.
Brad Wrench Fetcher, PhD | | | | | Joined: Oct 2015 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2015 Posts: 27 | (and what is a safe cleaner to remove Al anti-seize?)
Brad Try some WD-40 and finish up with some dish soap.. Brake Cleaner works as well, but not so safe...
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Dish soap may be the best bet. Coating on truck is single stage urethane. Thanks -
Brad Wrench Fetcher, PhD | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | a bit of gasoline on a rag, wipe the anti-sieze off quick, then wash the gas off with some warm soapy water (I like palmolive but just about any liquid dish soap should do fine) | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Gasoline should never be used for a cleaner. It's fumes are heavier than air and concentrate in low areas. A tragedy waiting for a spark. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Thanks for adding that info for the readers, cletis; Also-I've had enough fires in the garage this year.(Edit- gasoline would definitely work, though-thx) There must be something dish soap won't cut in this Al(-uminum) Anti-seize, though. It is smudgy. I'll move threads if I can't figure it out.
Brad
*** edit- glass cleaner is what you use ***
Wrench Fetcher, PhD | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 |
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I cut a piece of 1"x1" 9 ga. stainless square tube in half, lengthwise, to use under the 55.2's bed as reinforcing strips. They aren't perfect, but they are stout & I like 'em for the front & rear intermediate bolt hole locations. Brad Wrench Fetcher, PhD | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Hey Unk, Crank up that camera so we can see your project.
~Jim
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Random selection of pictures. Brad (Boy! Checking some pics to share in the link was a walk down memory lane- I haven't looked at most of those in a long time) Wrench Fetcher, PhD | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Well Jim, That's an impressive trail of work. Great work and attention to detail. Congratulations!
~Jim
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Made a new bump stop for the cab of my 1948 two ton. I had a new mount kit that had the replacement bump stop that was cone shaped with a 3/8" bolt in the center, but decided to cast some new rubber on the original plate from the bump stop that was stock. I think this type of bump stop was only 1947 and 1948. Pictures of my process are on the link. I made a mold then cast it with a urethane rubber. In the pictures there is an original I haven't re-cast. The rubber on the original was hard as a rock and shrunk down and it had separated from the mounting plate. I made the mold wider and got the height from the cone shaped replacement part I won't be using. http://s527.photobucket.com/user/Chevytwoton/slideshow/stop%20bumps A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Aug 2009 Posts: 152 'Bolter | | 'Bolter Joined: Aug 2009 Posts: 152 | Drove down to Mule1951's home in Cullman today and purchased a 1959 261 for my 1959 38 flatbed. Had a great time visiting and looking at his collection of 261s and assorted Task Force 38s. It was great to finally meet someone who enjoys the TF one ton trucks as much as I do, or maybe more.
Oldbolter 1959 Apache 3800 dually flat bed/dump with 261 1956 3800 dually flat bed/dump with 235 1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
| | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I took the 55.2's bed hardware, metal strips, & wood off. Then, I sanded all 16 edges of each board to round them for painting. Wiped the dust off of the boards, dryed them, & noticed I really need to wash the dust off of me.
Brad Wrench Fetcher, PhD | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Uncle Brad, you worked too hard. Your board only has 12 edges. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Maybe he sanded some of them twice!
| | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Super55, great job. Looks really good. I didn't like the aftermarket parts either, so I cut replacements out of a slab of 80 duro rubber and glued them to the original plates with rubber bonding epoxy. | | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | Finally all the bling pieces are in for the engine on the '48. Now I just need a bit warmer weather to get outside and put them on.
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Jim Sear, I wasn't sure what hardness to use on the ones I cast. The replacements were 60 duro. That's what I used. You can buy the cast urethane up to 90 duro. It's amazing how rock hard the old rubber stop bumps were when they dried out. Wish I could easily make the small metal plates that the rubber stops are mounted on. I could pour extras. I might "fake" the plates since the rubber mixtures have a short shelf life after you open them up. Also, I am not sure what the 3/4" hole's function is at the top of the rubber. It might have something to do with there mass production process. I put it in mine anyhow. That's what that metal mold is on top of the plaster mold in my pictures. http://s527.photobucket.com/user/Chevytwoton/slideshow/stop%20bumps A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | Uncle Brad, you worked too hard. Your board only has 12 edges. Count again... Brad Wrench Fetcher, PhD | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | I think you are both wrong...LOL, I count 32 different outside corners edges, 12 on each end and 8 down the length. But who's counting  Mike B  | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I am so confused!..LOL. Just put a piece of plywood in. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I just got the 2nd coat of POR-15 on the 55.2's bed wood underside- pictures. So, now is the waiting game for the 3rd coat on the bottom of the boards, then probably an early morning flip over to start the top sides. Brad Wrench Fetcher, PhD | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I have been working on the engine.cleaned the bare block and put it on the stand.I have the crankshaft back in it. | | | | | Joined: Apr 2014 Posts: 924 Shop Shark | | Shop Shark Joined: Apr 2014 Posts: 924 | I think you are both wrong...LOL, I count 32 different outside corners edges Mike B  That's correct, Mike. But this truck is a 2nd Series, so you have to divide by 2 and you get 16. My point was- it was a lot of sanding...I just got the 3rd coat of POR15 on the boards, so there is no way the wood will rust on the bottom side! Brad (sarcasm & dry humor are difficult to convey in print---that was me trying anyway) Wrench Fetcher, PhD | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | [quote=Mike B]My point was- it was a lot of sanding...I just got the 3rd coat of POR15 on the boards, so there is no way the wood will rust on the bottom side! You should have used POG-15 (paint over grain) much better suited to wood....  1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | My point was- it was a lot of sanding...I just got the 3rd coat of POR15 on the boards, so there is no way the wood will rust on the bottom side! So true Buddy! The hardest part of my build that exhausted and bored me more than any other part was my treatment with my bedwood and my bed rails.
~Jim
| | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | I worked on the engine.I had a problem when I tried to press the camshaft gear off.I broke the cam retainer plate. Now I will have to find one.shattered like glass. I did get the block cleaned ,the best I could in the parts washer,also the crankshaft and pistons ,all back in and torqued .
| | | | | | Neverdone Unregistered | | Neverdone Unregistered | 8 years in ,,I got my front and Rear bumpers on next is visor Screws Dan | | | | | Joined: Feb 2016 Posts: 3 New Guy | | New Guy Joined: Feb 2016 Posts: 3 | Just getting started in the projects. 48 1 ton. Feeling happy to have pulled the Carb, and getting down and dirty with the Carburetor cleanup. Looking pretty ugly, Will have to find a good rebuild kit for a Carter YF, and maybe some ultrasonic cleaning. Amazing that it still ran! (although pretty poorly at that)
1948 1 ton of fun
