| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | I can't get my glove box close all the way. I have tried everything and still come up with a 1/2 gap along the top. Tried moving the hinges up, down, in and out still the gap. Also have been bending the latch on the door, I think if I bend it much more it will come off the door. Need some HELP. 53 3100 root | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | Root,
I think the hinge adjustments only get you so far, they are more for the side to side. In order for it to close right (tight) I think you will need to carefully adjust the locking tang on the door. The key lock assembly has no real adjustment in its design. | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | Thanks Brad, that's what I thought I was going to have to do. I was hoping there was another way. Oh well, hope I don't break it. I guess if I do, maybe I can put back with steel pop rivets and epoxy. root | | |
