1 members (baldeagle), 110 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#1148884 02/07/2016 9:12 PM
I can't get my glove box close all the way. I have tried everything and still come up with a 1/2 gap along the top. Tried moving the hinges up, down, in and out still the gap. Also have been bending the latch on the door, I think if I bend it much more it will come off the door. Need some HELP. 53 3100 root
root #1148892 02/07/2016 9:37 PM
Root,
I think the hinge adjustments only get you so far, they are more for the side to side. In order for it to close right (tight) I think you will need to carefully adjust the locking tang on the door. The key lock assembly has no real adjustment in its design.
root #1149171 02/09/2016 1:49 AM
Thanks Brad, that's what I thought I was going to have to do. I was hoping there was another way. Oh well, hope I don't break it. I guess if I do, maybe I can put back with steel pop rivets and epoxy. root
Moderated by  ndkid275, Phak1
