2 members (Otto Skorzeny, 1955 1 Series), 116 guests, and 0 robots.
Topics128,115
Posts1,056,294
Members48,439
1 Offline
i have a 1939 Chevy 1.5 ton .i am putting a 350 v8 , i am having a challenge with the exhaust clearing the steering box can the steering box be moved sideways if so how much ,or use block huger headers , or move the engine forward , or switch to front motor mounts . any other recommendations . thank you 1pete1
Where on the manifold does the exhaust exit? There is a fellow with a Pontiac engine in a truck that installed the manifolds on the opposite sides so the outlets dropped out the front, not the rear. His pipes then ran under the front crossmember but away from all steering. Maybe you could find a manifold with a different outlet location and do something similar. Moving the steering box would be a challenge, you don't want to get into drag link angles or length problems.
A set of rear-dump Camaro exhaust manifolds swapped side to side and installed with the outlets pointing up would end up with a front crossover pipe like the old Ford 292's had. Then the exhaust pipe could be plumbed down the passenger's side away from the steering column. Odd-looking, but effective!
Big Bolt Forum Moderator
I am not a fan of block hugger headers, but I had them in my 59 Suburban and ran t hard. I had issues keeping the collector gaskets from burning out. (even with the deadsoft aluminum ones). I would print out some pictures and go to a wrecking yard and just poke around, looking at some different chevy manifolds. As suggested above, maybe swapping them side to side? My 588 2-ton, they ran exhaust out the top of the manifolds, through the inner fenders, and put stacks out the top of the fenders! It was a grain truck used on the farm though and they didn't want to catch the fields on fire. I am sure I would get pulled over if I was driving it around town here that way!
Mike
1 Offline
thank you for the replies great information , i will see what i can find in those exhaust manifodles . 1pete1
Crusing in the Passing Lane
Engine does not have to be exactly centered, port to starboard.
Ed
I used chevy 265 v-8 manifolds and then spaced the steering box out 1.5 inches.
Tim
1950 3600 Some Pictures
1951 3100
1952 3100 Some Pictures
