2 members (baldeagle, dunfire), 86 guests, and 3 robots.
Topics128,037
Posts1,055,467
Members48,424
#1146855 01/28/2016 12:12 AM
These are the ignition keys for my '48 Chevy 1/2 ton.
http://s160.photobucket.com/user/st...novsky/ignition%20keys?sort=3&page=1
Note that they have the same # stamped on them, yet the actual key blanks are different. Can someone "in-the-know" explain this? Seems a bit odd to me. Thanks.
LUKE
fonz8261 #1146866 01/28/2016 2:02 AM
Low bid contract for key blanks?
fonz8261 #1146869 01/28/2016 2:14 AM
I imagine both are aftermarket keys. Your original probably had Briggs and Stratton on it but the one shown doesn't have enough wear for a 68 year old key. The GM marked on is currently available.
fonz8261 #1147588 02/01/2016 3:27 AM
One should be the door key, the other the ignition key. Same number for the same truck.
1940 Chevy 1/2 ton pickup "KC"
A day without sunshine is like, well, ..... dark!
40casey #1147593 02/01/2016 3:44 AM
Both are ignition keys, just different blanks.
fonz8261 #1147595 02/01/2016 3:54 AM
How would anyone know if it is an ignition key, a door lock key, or a glove box lock key?
Wouldn't they all be the same pattern, if made for matching locks? Weren't the original locks matching (same keys)?
tclederman #1147600 02/01/2016 4:08 AM
These ignition keys have the same cut pattern, yet the blanks are different. I find it quirky that I have two different blanks for my ignition; would have thought that the key blanks would be the same.
fonz8261 #1147603 02/01/2016 4:10 AM
I just received key blanks for my '51 and the groves are on the opposite side of the key. The key I have for my ignition has the groves on the right side. Just my luck.
fonz8261 #1147605 02/01/2016 4:13 AM
There is a good possibility that one key or the other key or both keys are not the original keys that originally came with the truck?
tclederman #1147636 02/01/2016 6:17 AM
Both ignition keys work, and that is all that really matters. I am just fussing over something that is rather trivial.
fonz8261 #1147652 02/01/2016 2:04 PM
Ex Hall Monitor
Ex Hall Monitor
The B10 & B11 blanks were used back then. The hex head B10 was used for the ignition & doors. The round head B11 was used as the trunk & glove box key on cars. I don't know if the B11 was used on the trucks. B10 & B11 blanks.
fonz8261 #1147668 02/01/2016 4:44 PM
Trucks only used the B10. All locks were keyed the same. Ref: Factory assembly manual.
Cletis #1147759 02/02/2016 2:32 AM
On my 58 key it is what I call a pear shape briggs and Stratton number 8074 stamped just below the key ring hole. It operates the ignition and both doors. My glove box has no key slot.
fonz8261 #1147826 02/02/2016 3:34 PM
I seem to recall from my days of making keys (40+ years ago) that there were several Briggs & Stratton key blanks that had roughly the same grooves cut in them. If we were out of the correct (according to the book) blank we would just grab a different but compatible blank and cut the key. Customer didn't care just as long as the key worked. A little polishing with the wire wheel or a slight grind here or there with the cutter and all was well.
fonz8261 #1150715 02/17/2016 11:25 PM
Hi,
I was wondering where you can get key blanks. I just brought home a 55 first series C3100 and only got one set of keys. Everywhere I went ( hardware stores, Big Box) - they all said they do not have a blank, and don't think they can get one -
Anyplace you can recommend to get a blank would be appreciated
thanks
Joe F
Joe Finkelstine
Born and bred in Motown
fonz8261 #1150717 02/17/2016 11:31 PM
All over evil bay and Amazon. Just search Briggs &Stratton General Motors key blanks.
fonz8261 #1150720 02/17/2016 11:54 PM
Thanks martin
I found lots of blanks on Evil Bay, but now, is there any guide as to which blanks I need other than visually trying to match my actual key with an image?- it is a 1955 First series C3100 1/2 ton
thanks for your help!
Joe Finkelstine
fonz8261 #1150727 02/18/2016 12:35 AM
Find the oldest lock smith in your area and see if they have the blanks collecting dust...
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
fonz8261 #1150735 02/18/2016 1:47 AM
Joe, our resident key man Cletis will chime in soon with the blank # you need. I don't remember myself. Mike B has a good suggestion. Reread post a few back, seems like trucks used B10 blanks.
fonz8261 #1150742 02/18/2016 2:57 AM
Yes, a B10 blank is what you need. And you should not have any trouble finding them locally. Are you sure you have an original ignition switch?
fonz8261 #1150745 02/18/2016 3:04 AM
1933 - 1966 used that blank for ignition. The b-11 is for trunks, etc.
ACE Hardware,,Orchard Supply,,Home Depot.
I get all my bulk blanks from www.ekeys.com and make copies of my master key set.
Cletis #1151573 02/22/2016 10:28 PM
Hi All
thanks for the good advise, and to your question Cletis, I am not 100% certain I have an original ignition switch, but the one key I have looks much like to B10 blanks I see
How would I check for original switch on this truck?
Joe Finkelstine
