2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
Page 137 of 177 1 2 … 135 136 137 138 139 … 176 177
I decided my 53 AD needed a clock. I know they did not offer a dash mounted clock so I just made a 53-54 car clock work. I found a 3 inch ID female to female exhaust PIPE connector to use as a housing. Welded two TABS to the inside. Cut it to MATCH the dash. It looks GOOD to ME
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
Looks good.Nice job
looks real nice, great job.
Stovebolt Photo Moderator
That clock looks great. Today I put the 47 3800 dually AD on a trailer and towed her down to my welder buddy. I cut all the old panels away last weekend. I left him with new panels. I can't wait to get the phone call.....come and get it. Joe
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
Finally got the correct speedometer cable housing that goes into the automatic trans on my panel. Finally, the leak is gone.
Hey Mike, darn good job on the clock housing. Beats the 400 or more some want for them!
It was suggested sometime ago we had a place to post these sort of ideas/developments. It sure would be nice.
Did you make two?? One would like nice on the panel dash!
amtrackjoe, be sure and post pictures.
Originally Posted by blanch53
I like the air filter that you installed, could you share the modification details as to how you mounted it...thanks
Hey Blanch - I had a standard oil bath filter housing base that was rusted thru in a few spots. So I cut the bottom out of it (somewhat oversize), keeping the center part with the stock pinch clamp that goes over the top of the stock carb. Now you basically have a 6" or so diameter disk.
I cut off the "pipe" sort of sheet metal that sticks up into the upper assembly of the oil bath filter, the part with the stud the wing nut threads on to, there's no need for it anymore.
Next I brazed the bottom of the Edelbrock filter to this "disk" with the pinch clamp. I brazed it in 4-5 spots around the inside perimeter. It was too thin for my welding skills, brazing was safer.
I mixed up some JB Weld and applied a bead to the areas where there wasn't brazing, just to seal off any short cuts unfiltered air could take.
Then I trimmed the extra material from the outside until it matched the Edelbrock base diameter.
At that point the rest is cosmetic stuff, sanding, painting.
Now you have a filter that mounts as an original would.
'59 Apache
‘21 Beta 390RS
‘18 BMW R1200RT
'12 Ford Flex
'13 Aprilia Tuono
‘11 Ducati Hypermotard
Salisbury, MD
I
I Offline
this weekend i replaced the door latch and window regulator. fought with installing the vent assembly for hours until I removed the back channel screws, which gave me the wiggle room needed to seat the glass into the front channel. Recently pulled the Harrison Fresh Air heater, pulled the core which was leaking and had a local shop re braze the core. This is a 53 3100 daily driver for my daughter.
1953 3100 5 Window
1959 American LaFrance
Tossed a couple gallons of 'real' gasoline into my tank since inserting a debris strainer into the outlet valve; checked for leaks around the valve and fittings... nice and dry.
Got her restarted no problem and after idling for 10 or 15 minutes, it started flooding all of a sudden. Sheesh...
Installed the freshly delivered passenger side engine frame perch for the 292 in the 71 GMC.
Masked / first coat of flat black on the grill..
(2) 1954 3100's / foster parent - SOLD
1955.1 3100 Resto in progress
1971 GMC 2500 Custom / foster parent
1951 M37 Lawn ornament
1949 3800 Panel Resto in progress
1959 GMC 100 LB Fleetside
U
U Offline
I know it's my own doing, but it has been flat out weird working on my truck and not getting filthy dirty the past few weeks. Tonight, I started removing all the bed wood bolts to remove the wood for paint. I was grabbing the frame, springs, cross sills, drive shaft, differential- whatever was there and I'm getting the truck dirty as opposed to vice versa... (and what is a safe cleaner to remove Al anti-seize?)
Maybe I just got hooked on fast orange or something & haven't used it for a while.
Brad
Wrench Fetcher, PhD
Brad
Try some WD-40 and finish up with some dish soap..
Brake Cleaner works as well, but not so safe...
U
U Offline
Dish soap may be the best bet. Coating on truck is single stage urethane. Thanks -
Brad
Wrench Fetcher, PhD
Big Bolt Forum Moderator
a bit of gasoline on a rag, wipe the anti-sieze off quick, then wash the gas off with some warm soapy water (I like palmolive but just about any liquid dish soap should do fine)
Mike
Gasoline should never be used for a cleaner. It's fumes are heavier than air and concentrate in low areas. A tragedy waiting for a spark.
U
U Offline
Thanks for adding that info for the readers, cletis; Also-I've had enough fires in the garage this year.(Edit- gasoline would definitely work, though-thx) There must be something dish soap won't cut in this Al(-uminum) Anti-seize, though. It is smudgy. I'll move threads if I can't figure it out.
Brad
*** edit- glass cleaner is what you use ***
Wrench Fetcher, PhD
Acetone?
U
U Offline
I cut a piece of 1"x1" 9 ga. stainless square tube in half, lengthwise, to use under the 55.2's bed as reinforcing strips. They aren't perfect, but they are stout & I like 'em for the front & rear intermediate bolt hole locations.
Brad
Wrench Fetcher, PhD
Hey Unk,
Crank up that camera so we can see your project.
~Jim
U
U Offline
Random selection of pictures.
Brad
(Boy! Checking some pics to share in the link was a walk down memory lane- I haven't looked at most of those in a long time)
Wrench Fetcher, PhD
Installed my radiator today:
http://ssrjim.wordpress.com
Well Jim,
That's an impressive trail of work. Great work and attention to detail. Congratulations!
~Jim
Big Bolt Forum Co-moderator
Made a new bump stop for the cab of my 1948 two ton. I had a new mount kit that had the replacement bump stop that was cone shaped with a 3/8" bolt in the center, but decided to cast some new rubber on the original plate from the bump stop that was stock. I think this type of bump stop was only 1947 and 1948. Pictures of my process are on the link. I made a mold then cast it with a urethane rubber. In the pictures there is an original I haven't re-cast. The rubber on the original was hard as a rock and shrunk down and it had separated from the mounting plate. I made the mold wider and got the height from the cone shaped replacement part I won't be using.
http://s527.photobucket.com/user/Chevytwoton/slideshow/stop%20bumps
1948 Chevy 2-Ton
Drove down to Mule1951's home in Cullman today and purchased a 1959 261 for my 1959 38 flatbed. Had a great time visiting and looking at his collection of 261s and assorted Task Force 38s. It was great to finally meet someone who enjoys the TF one ton trucks as much as I do, or maybe more.
Oldbolter
1959 Apache 3800 dually flat bed/dump with 261
1956 3800 dually flat bed/dump with 235
1957 3600 flat bed, 350 engine, 700R4, PS, disc brakes, 14 bolt rear with 4.11 gears
U
U Offline
I took the 55.2's bed hardware, metal strips, & wood off. Then, I sanded all 16 edges of each board to round them for painting. Wiped the dust off of the boards, dryed them, & noticed I really need to wash the dust off of me.
Brad
Wrench Fetcher, PhD
Uncle Brad, you worked too hard. Your board only has 12 edges.
1948 Chevy 2-Ton
Maybe he sanded some of them twice!
Super55, great job. Looks really good.
I didn't like the aftermarket parts either, so I cut replacements out of a slab of 80 duro rubber and glued them to the original plates with rubber bonding epoxy.
Finally all the bling pieces are in for the engine on the '48. Now I just need a bit warmer weather to get outside and put them on.
Jim Sear, I wasn't sure what hardness to use on the ones I cast. The replacements were 60 duro. That's what I used. You can buy the cast urethane up to 90 duro. It's amazing how rock hard the old rubber stop bumps were when they dried out. Wish I could easily make the small metal plates that the rubber stops are mounted on. I could pour extras. I might "fake" the plates since the rubber mixtures have a short shelf life after you open them up. Also, I am not sure what the 3/4" hole's function is at the top of the rubber. It might have something to do with there mass production process. I put it in mine anyhow. That's what that metal mold is on top of the plaster mold in my pictures.
1948 Chevy 2-Ton
U
U Offline
Count again...
Brad
Wrench Fetcher, PhD
I think you are both wrong...LOL, I count 32 different outside corners edges, 12 on each end and 8 down the length.
But who's counting eeeek
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
I am so confused!..LOL. Just put a piece of plywood in.
1948 Chevy 2-Ton
U
U Offline
I just got the 2nd coat of POR-15 on the 55.2's bed wood underside- pictures. So, now is the waiting game for the 3rd coat on the bottom of the boards, then probably an early morning flip over to start the top sides.
Brad
Wrench Fetcher, PhD
I have been working on the engine.cleaned the bare block and put it on the stand.I have the crankshaft back in it.
U
U Offline
Mike B smile
That's correct, Mike. But this truck is a 2nd Series, so you have to divide by 2 and you get 16.
My point was- it was a lot of sanding...I just got the 3rd coat of POR15 on the boards, so there is no way the wood will rust on the bottom side!
Brad (sarcasm & dry humor are difficult to convey in print---that was me trying anyway)
Wrench Fetcher, PhD
[quote=Mike B]My point was- it was a lot of sanding...I just got the 3rd coat of POR15 on the boards, so there is no way the wood will rust on the bottom side!
You should have used POG-15 (paint over grain) much better suited to wood.... wink
More pix on Flickr.
So true Buddy! The hardest part of my build that exhausted and bored me more than any other part was my treatment with my bedwood and my bed rails.
~Jim
I worked on the engine.I had a problem when I tried to press the camshaft gear off.I broke the cam retainer plate. Now I will have to find one.shattered like glass.
I did get the block cleaned ,the best I could in the parts washer,also the crankshaft and pistons ,all back in and torqued .
Neverdone
Unregistered
Neverdone
Unregistered
8 years in ,,I got my front and Rear bumpers on next is visor Screws
Dan
Just getting started in the projects. 48 1 ton. Feeling happy to have pulled the Carb, and getting down and dirty with the Carburetor cleanup. Looking pretty ugly, Will have to find a good rebuild kit for a Carter YF, and maybe some ultrasonic cleaning. Amazing that it still ran! (although pretty poorly at that)
1948 1 ton of fun
