3 members (Steelonsteel, Patina 54, CandoBrent), 42 guests, and 3 robots.
Topics128,034
Posts1,055,440
Members48,422
#114744 03/21/2005 8:43 PM
I had a post running in General on what color to paint my dash. Maybe you saw it. I finally pulled out of the pile my old dash and put some rubbing compound to it to take a look at the original color which if Biege "Hammered". After looking this over the Hammered must mean the fish eyed appearance that the paint has.
Anyone out there know how to get that hammered effect? Is there a special product, procedure, method to do this. Or is this something that they did way back when in the factory, and we just can't duplicate it now.
Any help out there? comments?
Regards, Kevin
1940 1/2-ton (Uncle Willie\'s truck)
Thanks for the help so far fellow Bolters!
#114745 03/21/2005 9:52 PM
You can get the paint in rattle cans at both Ace Hardware or any major hardware store. It's also available by the qt. from Jim Carter. The only thing is the color selection is not all that large. Cecil........
#114746 03/21/2005 10:17 PM
51Jimmy, Do you know if the stuff from Jim Carter has that effect? I saw he has beige but didn't know if it was Hammered.
Thanks for the reply.
Regards, Kevin
#114747 03/21/2005 10:37 PM
FYI... I talked with the good folks at Jim Carter and the paint that they sell is just a spray on and the "Hammer" effect takes shape.
Sounds to easy. I may try it.
Regards, Kevin
#114748 03/22/2005 12:15 AM
No, the only one JC has is the color for the heater. The more I think about it, a automotive paint shop is probably your best bet. Could take the part over and have some of the people take a look at it and get better idea of where you go from here. Like the job you've done on your frame and brakes so far, it looks like your doing a A1 job. Cecil.......
#114749 03/22/2005 2:19 AM
I use the hammer type finish on early series AD radios. I bought mine at a local automotive/general supply house. the result varies with your technique. Some times flowing it on gives a good pronounced hammer affect. If you go over it again, sometimes it will look almost like regular paint. Probably practice is the best bet to success here.
1951 1 Ton Completed
#114750 03/22/2005 3:36 AM
Check out www.kilz.com a product called "Hammerite" 11 colors cool
1965 C-10 Stepside
#114751 03/22/2005 3:43 AM
oops forgot Eastwood has 8 of the colors smile
1965 C-10 Stepside
#114752 03/22/2005 5:57 PM
I bought a quart from JC and they advertize it as the original hammered interior color for the '40. I will try it and let you all know.
The Kilz hammerite product looks a little more like cottage cheeze then the original fish eye/marblely look.
Thanks for the tip on the heater. I hadn't thought that far ahead yet but I think it also has the hammered look.
This is just one big learning experience!!!
Regards, Kevin
#114753 03/22/2005 6:17 PM
that Hammerite is tough to apply - dries instantly so ya hafta be real careful using a brush to avoid 'drag' - looked good for my 46 interior tho'
I used Plasti-kote spray bombs of silver "Hammer Finish" on some of the interior of my 58, and it looks great - works well as replacement for the original on the heater cover
#114754 03/22/2005 9:17 PM
For smaller parts, you can get a hammer-finish powder coating.
1954 GMC De Luxe COE
#114755 03/23/2005 12:09 AM
I
I Offline
I used hammer finish paint on my dining set.
It seemed like I had to putt it on thick to get it to "Hammer"
Almost to the point of drips.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
#114756 03/27/2005 1:48 PM
red58 -
Ya got any pictures posted anywhere of how the 58 interior turned out using the hammer finish from the rattle cans?
Bodega Bob
http://www.submarinestore.com
Where's my tin foil hat?!?
#114757 03/28/2005 3:36 AM
Do you use a primer? I bought a quart from JC and wasn't able to find out if it needs a primer or what type to use. I sandblasted my heater, so it will be clean when I spray it, but logic tells me I should prime it. Any body have a thought?
#114758 03/28/2005 4:24 AM
Bob - only shot of the 58 inside on hand - looks better than this pic, but haven't done the whole thing yet, will maybe do more this summer - here\'s a poor shot of the deluxe heater I'm workin on for the current 57 panel, and here\'s a shot of the 57 frankentruck\'s cab w/ a darker plain gray dash top and door panel insert - gets lotsa compliments! grin
Jake - I used spray bomb primer on somea the things, not on others - inside it's not as important as when exposed to the elements - some things on the 57 got primered at the next door body shop when apart getting tin bashed - I drive these trucks, so not looking for show quality, just something that'll make'em last and be 'presentable' - I do 'resurrections' not restorations grin the important part on a heater is actually the inside which is where they corrode first due to condensation and leaks, and I've used the zinc based weld-thru spray bombs for that
#114759 03/30/2005 3:40 AM
Kevin - "Hammerite" is a pretty good product in rattle cans that will give you the effect you're looking for. It requires no primer and will encapsulate rust. Just wire brush and clean the loose stuff the best you can. You'll have to practice spraying it. Usually just 1 or 2 passes.
#114760 03/30/2005 6:02 PM
Hey Bill, nice lookin interior on the 57. Tell me, what's the (looks like a) red light on the little panel to the right of the radio area?
Larry Bear
55.5 Chevy 3100 Panel
