6 members (55shaker, Wickedbass, FAST55, rfs56trk, Hotrod Lincoln, Hanks custodian), 57 guests, and 3 robots.
Topics128,065
Posts1,055,868
Members48,428
#114724 01/21/2003 10:46 PM
I need to de-rust the inside of my doors. Its not rusted thru any were just a lot of surface rust and scale. I was wondering if anyone has cut out the interior door skin then sand blasted the inside of the door then welded the skin back in place. Will that work? That opening in the bottem corner is almost to small to do anything. Any suggestions. Thanks!
grin
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces
2000 GMC Serria 1500 SL 4x4
#114725 01/21/2003 10:53 PM
They get rusty in there because water runs down there. Sandblasting will only remove the "pickle" and make them rust through faster. I would just introduce a good amount of POR-15 or Zerorust and slosh it around in there until you think they are completely coated inside. After removing the latches and window hardware, of course.
Paint & Body Shop moderator
#114726 01/21/2003 11:07 PM
thanks! I have them down bare bones right now. Zero Rust was the plan from the get go after blasting. But I guess basting both side of it might be to much. grin
#114727 01/22/2003 6:11 AM
Anonymous
Unregistered
Anonymous
Unregistered
Time to locate a couple of rust free Arizona doors. grin
#114728 01/22/2003 8:43 AM
I feel for you guys trying to fix up a less than rust free truck. I had rust on a truck once. The truck was from IL ofcourse.
54 3100 with 235
62 flatbed dump C60 with 261
#114729 01/22/2003 8:56 PM
You aint seen anything rust faster then bare metal on a hot muggy day in Arkansas. Or any day in Arkansas for that matter!
eek
#114730 01/23/2003 8:01 PM
Apprentice
Apprentice
Does anyone know if a anyone makes door skins for AD trucks? If so, that would be great for me. then I don't have to hunt down a new door. Mine is pretty beat up.
Everything you know is wrong.
