10 members (sron48, Donf, Bill Hanlon, rfs56trk, Hanks custodian, Wally / Montana, ranchojuan, jkreiner, fonz8261, TexasJim50),
49
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,074 Posts1,055,914 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | I need to de-rust the inside of my doors. Its not rusted thru any were just a lot of surface rust and scale. I was wondering if anyone has cut out the interior door skin then sand blasted the inside of the door then welded the skin back in place. Will that work? That opening in the bottem corner is almost to small to do anything. Any suggestions. Thanks!
"Finish the thing, do it right the first time, and drive the S.O.B.!"
1949 Chevy half ton 3100 In a kazillion pieces 2000 GMC Serria 1500 SL 4x4
| | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | They get rusty in there because water runs down there. Sandblasting will only remove the "pickle" and make them rust through faster. I would just introduce a good amount of POR-15 or Zerorust and slosh it around in there until you think they are completely coated inside. After removing the latches and window hardware, of course.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | thanks! I have them down bare bones right now. Zero Rust was the plan from the get go after blasting. But I guess basting both side of it might be to much.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | Time to locate a couple of rust free Arizona doors.  | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I feel for you guys trying to fix up a less than rust free truck. I had rust on a truck once. The truck was from IL ofcourse.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jul 2001 Posts: 149 Member | | Member Joined: Jul 2001 Posts: 149 | You aint seen anything rust faster then bare metal on a hot muggy day in Arkansas. Or any day in Arkansas for that matter!
| | | | | Joined: Jan 2003 Posts: 33 Apprentice | | Apprentice Joined: Jan 2003 Posts: 33 | Does anyone know if a anyone makes door skins for AD trucks? If so, that would be great for me. then I don't have to hunt down a new door. Mine is pretty beat up.
Everything you know is wrong.
