3 members (Wally / Montana, Sjm, Peggy M), 136 guests, and 4 robots.
Topics128,264
Posts1,058,357
Members48,485
#114691 01/16/2003 4:53 AM
Apprentice
Apprentice
The front panel of the bed on my '47 1 ton is a goner. I pulled all the bolts along the outside of the side panels EXCEPT the ones at the top which thread into the rolled top tube. My guess is they are carrage bolts and both have stripped. Do I cut them out? Is there some other way to get them out? Any help appreciated.
Don't read the directions, that'd be too easy.
I think that top one is one long bolt or threaded rod. My '37 was, it had two square nuts, one on each side. You may have to cut one side if it is striped, then pull out from the other side. Joe
Yep, it is one long rod that goes through the whole thing from side to side. Strange, that is all I can say.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
