| | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2003 Posts: 48 Apprentice | | Apprentice Joined: Jan 2003 Posts: 48 | The front panel of the bed on my '47 1 ton is a goner. I pulled all the bolts along the outside of the side panels EXCEPT the ones at the top which thread into the rolled top tube. My guess is they are carrage bolts and both have stripped. Do I cut them out? Is there some other way to get them out? Any help appreciated.
Don't read the directions, that'd be too easy.
| | | | | Joined: Feb 2000 Posts: 5,264 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,264 | I think that top one is one long bolt or threaded rod. My '37 was, it had two square nuts, one on each side. You may have to cut one side if it is striped, then pull out from the other side. Joe | | | | | Joined: Oct 2000 Posts: 804 Shop Shark | | Shop Shark Joined: Oct 2000 Posts: 804 | Yep, it is one long rod that goes through the whole thing from side to side. Strange, that is all I can say.
1948 Chevy Pickup Chopped and sectioned owned since 1974 when I was 15.
