2 members (BC59, Uncles51),
103
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,041 Posts1,055,481 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,752 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,752 | Low bid contract for key blanks? Jerry
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I imagine both are aftermarket keys. Your original probably had Briggs and Stratton on it but the one shown doesn't have enough wear for a 68 year old key. The GM marked on is currently available. | | | | | Joined: Mar 2011 Posts: 457 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 457 | One should be the door key, the other the ignition key. Same number for the same truck.
1940 Chevy 1/2 ton pickup "KC" A day without sunshine is like, well, ..... dark! | | | | | Joined: Jun 2009 Posts: 787 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 787 | Both are ignition keys, just different blanks. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Both are ignition keys, just different blanks. How would anyone know if it is an ignition key, a door lock key, or a glove box lock key? Wouldn't they all be the same pattern, if made for matching locks? Weren't the original locks matching (same keys)? | | | | | Joined: Jun 2009 Posts: 787 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 787 | These ignition keys have the same cut pattern, yet the blanks are different. I find it quirky that I have two different blanks for my ignition; would have thought that the key blanks would be the same. | | | | | Joined: Sep 2010 Posts: 49 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 49 | I just received key blanks for my '51 and the groves are on the opposite side of the key. The key I have for my ignition has the groves on the right side. Just my luck. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | These ignition keys have the same cut pattern, yet the blanks are different. I find it quirky that I have two different blanks for my ignition; would have thought that the key blanks would be the same. There is a good possibility that one key or the other key or both keys are not the original keys that originally came with the truck? | | | | | Joined: Jun 2009 Posts: 787 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 787 | Both ignition keys work, and that is all that really matters. I am just fussing over something that is rather trivial. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | The B10 & B11 blanks were used back then. The hex head B10 was used for the ignition & doors. The round head B11 was used as the trunk & glove box key on cars. I don't know if the B11 was used on the trucks. B10 & B11 blanks.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Trucks only used the B10. All locks were keyed the same. Ref: Factory assembly manual. | | | | | Joined: Feb 2008 Posts: 212 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 212 | On my 58 key it is what I call a pear shape briggs and Stratton number 8074 stamped just below the key ring hole. It operates the ignition and both doors. My glove box has no key slot. | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | I seem to recall from my days of making keys (40+ years ago) that there were several Briggs & Stratton key blanks that had roughly the same grooves cut in them. If we were out of the correct (according to the book) blank we would just grab a different but compatible blank and cut the key. Customer didn't care just as long as the key worked. A little polishing with the wire wheel or a slight grind here or there with the cutter and all was well.
| | | | | Joined: Dec 2015 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 56 | Hi, I was wondering where you can get key blanks. I just brought home a 55 first series C3100 and only got one set of keys. Everywhere I went ( hardware stores, Big Box) - they all said they do not have a blank, and don't think they can get one -
Anyplace you can recommend to get a blank would be appreciated
thanks
Joe F
Joe Finkelstine Born and bred in Motown
| | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | All over evil bay and Amazon. Just search Briggs &Stratton General Motors key blanks.
| | | | | Joined: Dec 2015 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 56 | Thanks martin I found lots of blanks on Evil Bay, but now, is there any guide as to which blanks I need other than visually trying to match my actual key with an image?- it is a 1955 First series C3100 1/2 ton
thanks for your help!
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Find the oldest lock smith in your area and see if they have the blanks collecting dust... Mike B  | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Joe, our resident key man Cletis will chime in soon with the blank # you need. I don't remember myself. Mike B has a good suggestion. Reread post a few back, seems like trucks used B10 blanks.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, a B10 blank is what you need. And you should not have any trouble finding them locally. Are you sure you have an original ignition switch? | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | 1933 - 1966 used that blank for ignition. The b-11 is for trunks, etc. ACE Hardware,,Orchard Supply,,Home Depot. I get all my bulk blanks from www.ekeys.com and make copies of my master key set. | | | | | Joined: Dec 2015 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 56 | Hi All thanks for the good advise, and to your question Cletis, I am not 100% certain I have an original ignition switch, but the one key I have looks much like to B10 blanks I see
How would I check for original switch on this truck?
