3 members (klhansen, tricordati, Pre '68 Dave), 91 guests, and 2 robots.
Topics128,096
Posts1,056,477
Members48,444
#1146844 01/27/2016 10:58 PM
Moderated
Moderated
my 41 PU has two trumpet horns, one larger than other, but I can't seem to get both working together, both sound when alone.
Ed41 #1146849 01/27/2016 11:33 PM
Do your horns have a common relay? Is it working?
Have you tested for voltage at the horns with someone pushing the button?
Do you have clean grounds at the horns?
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Ed41 #1146966 01/28/2016 7:14 PM
Ex Hall Monitor
Ex Hall Monitor
This what they look like? If so, as noted above they work in unison using a relay.
Ed41 #1147164 01/29/2016 6:05 PM
I have a pair of dual horns also that I will be hooking up to a relay. The horns are supposed sound at the same time right? or do they sound one right after the other?
Ed41 #1147169 01/29/2016 6:49 PM
Big Bolt Forum Moderator
as stated above, they should sound at the same time, sounds like they are not getting enough current to sound them both. Could be a bad ground or faulty/weak relay.
Mike
Ed41 #1147213 01/29/2016 10:39 PM
Ex Hall Monitor
Ex Hall Monitor
Your relay will have three tabs. The relay mounts to the center part of the trumpet horn bracket in the orientation shown in the above picture. Your hot wire comes directly from the battery post on the starter to the center tab. The passenger side tab connects to the hot wires for both horns. The driver's side tab connects to the horn button. If necessary I'll take a picture of mine & post it.
