1 members (Otto Skorzeny), 85 guests, and 2 robots.
Topics128,162
Posts1,056,936
Members48,458
Hey Guys,
Starting my first build tread on the peach! Just a little background on the truck, I bought it in the fall in Salmon Arm BC and brought it back to Calgary. It was pretty complete, everything was there but just barely held together with a couple bolts. We originally thought it looked pretty good but once the tear down began we started to realize we got ourselves into something way bigger then anticipated. Lets just say a magnet would have been a wise thing to bring with when we bought the truck!
Anyhow I've slowly been buying all the tools I need from a sandblaster to a plasma cutter and much more. I've completely torn down the truck and am currently rebuilding the front cab rockers and door hinge mounts at the moment. I've got one side nearly done and about half of the other side. Once they are both complete I will move on to replacing most of the firewall, the entire floor and cab mounts.
The plan is to move it to a newer S-10 chassis and either a small v8 or if we can find a reasonably priced newer diesel to put in it go that way! Anyhow, hope everyone enjoys the ride and please, constructive criticism is more then welcome! I'm learning so if you guys see something that you would have done differently let me know. Ideas are also great!
Here's my photo album of the truck so far!
Matts 54 Album
Cheers,
Matt
1954 Chev 3100
“When I’m working on a problem, I never think about beauty. I think only how to solve the problem. But when I have finished, if the solution is not beautiful, I know it is wrong.” R. Buckminster Fuller
Thanks for the pics Matt. My, you been a busy man. Your work looks good.
Todays update. I welded in a couple more panels on the drivers side of the cab. Don't know the technical names for all these piece but here's some pics...
Front Left Cab Lower Panel
Front Left Cab Middle Panel
Front Left Cab Mirror Patch
Front Left Cab Side
My question of the day is, how much bondo is reasonable to use. I have noticed grinding down some of my welds that at times they have a bit of a concave shape and are hard to grind, at times leaving "pits" behind. I'm guessing most people just bondo that stuff but I'm unsure if it is something I'm doing wrong welding or if it is common and not to be worried about. Here's an example from today, I welded in a small patch by firewall/hood area and I could not grind out the little pits with reasonable confidence in the strength of steel left behind...
Pits
1954 Chev 3100
The main considerations with using body fillers and stopping rust are are:
1. all sides of the metal can/will rust if exposed to any air/water
2. you want to grind/buff/sand/media-blast to shiney metal on all sides
3. you need to seal all sides of the metal with a water/moisture-proof sealant - a 2-part epoxy primer - is the best choice for sealing the metal
4. body filler (compatible with the primer) is used over the epoxy primer
5. sand
6. if any metal shows after sanding, you need to cover with another epoxy coat
7. maybe someone will comment on sander-surfacer coats
8. someone will correct and/or add-to/clarify the brief items in this list
Maybe someone will post a link to a good tutorial on the Internet?
Not to change the topic but ater looking at your photo album.
I noticed in this PHOTO the starter solenoid is on the side of the starter.
The solenoid is normally mounted on the top of the starter.
The stock 1954 Chevrolet 1/2 ton truck was equipped with a foot operated floor starter. No solenoid.
Obviously someone installed a different starter.
I've never seen a solenoid mounted on the side of the starter.
The 1954 stock 6v GM solenoid starter used on DD, and Hydramatic-equipped trucks (and on COEs) had the solenoid on the top (as described by jorb).
Maybe it is a Canadian starter, or a different clutch-housing/flywheel for a different transmission/drive-train?
From what I understand the engine is not stock, I believe it is a 235 if that makes any difference. I think the transmission and everything else is original/stock. I'l be using a more modern frame and engine in my build so I haven't really done any research into the old straight 6's. Anyhow thanks for the info Tim!
Here's todays work, not much just tacked the front drivers side fender mount piece onto the cab. Took a while to get it formed to my satisfaction.
Drivers Side Cab fender Mount Piece
1954 Chev 3100
Hi,
I need a speedometer gear for my '54 3100 3 spd transmission [ closed driveshaft ]if your old one is available. might even take the whole transmission if I have to.
Thanks for the consideration
JB
personal buying/selling should take place in email or in Private Messages
Former Workshop Owner
Hey Matt,
Looking good, I really like the chrome grills on the 54's and 1st series 55's. Thanks for sharing the pics.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Moderated by  J Lucas
