| | | Forums66 Topics128,090 Posts1,056,018 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | Need help choosing what thickness of glass setting tape to order. (Not interested in using silicone or urethane.)
The side window gap is about .079 in. Does this indicate 5/64 (.078) or 3/32 (.094) tape?
The windshield gap is .051 on the driver side and .045 on the passenger side (due to slight difference in glass thickness). Does this indicate 3/64 (.047) or 1/16 (.063) tape?
I'm guessing tape slightly thinner than the gap is desirable for ease of assembly, assuming modern glass setting tape is still able to be swelled by oil. Otherwise I would think slightly thicker tape would be required to prevent water intrusion. Which is correct? | | | | | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | You need tape half the thickness of the gap since the tape centers the glass in the channel. I bought mine from the local automotive glass shop, seem to remember is was really cheap or he gave me a good deal on it. | | | | | Joined: Oct 2012 Posts: 182 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 182 | The gap I stated above was the "per side" gap, the total gap divided by two. | | | | | Joined: Oct 2015 Posts: 9 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 9 | I would suggest going for the thicker tape for a tighter fit to keep moisture out. If it ends up being too thick to install you can always remove it and go with the thinner option. | | |
