5 members (tclederman, DadsFirstPickup, 59 fleet, IHPWR, Ponchogl), 102 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
Need help choosing what thickness of glass setting tape to order.
(Not interested in using silicone or urethane.)
The side window gap is about .079 in. Does this indicate 5/64 (.078) or 3/32 (.094) tape?
The windshield gap is .051 on the driver side and .045 on the passenger side (due to slight difference in glass thickness). Does this indicate 3/64 (.047) or 1/16 (.063) tape?
I'm guessing tape slightly thinner than the gap is desirable for ease of assembly, assuming modern glass setting tape is still able to be swelled by oil. Otherwise I would think slightly thicker tape would be required to prevent water intrusion. Which is correct?
You need tape half the thickness of the gap since the tape centers the glass in the channel. I bought mine from the local automotive glass shop, seem to remember is was really cheap or he gave me a good deal on it.
The gap I stated above was the "per side" gap, the total gap divided by two.
I would suggest going for the thicker tape for a tighter fit to keep moisture out. If it ends up being too thick to install you can always remove it and go with the thinner option.
