0 members (),
120
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2015 Posts: 5 New Guy | | New Guy Joined: Sep 2015 Posts: 5 | I have read that bolting on a holley 500 two barrel carb to my gmc 351 v6 is the way to go, but where do I get the adapter to do the swap? | | | | | Joined: Nov 2002 Posts: 2,774 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,774 | The short answer:
There used to be, and maybe still is, a company in California called Trans-Dapt that made the adapter.
The long answer (or to quote Paul Harvey, the rest of the story):
Several years ago, we read/heard/whatever the same thing about replacing the Stromberg with the Holley. Since we own what is left of Stromberg, we had customers asking about the swap. So we bought 6 of the adapters and 6 of the Holleys; and sold them all in the summer. During the summer, all was well, except the gas mileage decreased dramatically from the Stromberg, but the trucks ran OK. And then winter came, and to start the trucks, the choke must be used. And every miserable one of the chokes BROKE on the Holleys. We had to take every one of them back and refund the full purchase price! And since they were broken, Holley would not take them back from us. Worst financial decision I have ever made!!!!!
I threw them all in a used 20 gallon garbage can (literally) and sold the can and its contents for the price of a new garbage can to a circle track racer.
So make the change if you want, but I would highly suggest rebuilding and keeping your original Stromberg if you want to drive the truck in the winter!
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Will a 500 CFM Rochester work? | | | | | Joined: Nov 2002 Posts: 2,774 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,774 | The large Rochester world require a different adapter, but yes, it could be made to work; but why???
If you are looking for reliability, the Stromberg has only one reliability issue, the aluminum throttle body. Once a competant rebuilder has installed bushings to prevent throttle shaft/throttle body wear; they are bullet-proof! And the larger Strombergs came from the factory with roller-bearings which totally eliminated this issue.
If you are hot-rodding the engine, the Strombergs came in a variety of venturii sizes, and were used on G.M.C. V-6's up to 478 CID and EVERYTHING STILL FITS!
The Strombergs have one major disadvantage (shared by the Rochester) when compared to the Holley. Every parts store in the world has Holley parts; and don't carry Stromberg or Rochester parts. But both the Stromberg and Rochester parts are readily available mail order.
We have been selling the Strombergs to Buick, Cadillac, and Packard owners of mid-1930's cars for lots of years, because they are so reliable, and often much less expensive than the original.
But yes, Trans-Dapt probably had an adapter to replace the Stromberg with the larger Rochester.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: May 2012 Posts: 574 'Bolter | | 'Bolter Joined: May 2012 Posts: 574 | I used a mr.gasket adapter part number 1937 with the holley 500 cfm, no problems yet this winter driving it almost daily
1949 Dodge Coronet 1955 2nd Chevy 4400 1.5 ton 1955 2nd Chevy 3100 1/2 ton 1955 2nd Chevy 3100 1/2 ton 1957 Chevy 5400 LCF 2 ton 1966 Dodge D100 Sweptline 1968 Chevy P20 stepvan 1969 GMC LWB pickup 1972 GMC Sprint 1974 CP30 shorty bus There are three things that I've learned never discuss with people: religion, politics, and the Great Pumpkin.----Linus Van Pelt Trying to understand the behavior of some people is like trying to smell the color 9 | | |
