Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (TUTS 59), 45 guests, and 1 robot.
Topics128,009
Posts1,055,296
Members48,419
#1144571 01/14/2016 1:05 AM
Woj
Offline
I am new to Stovebolt and am in need for some advice. In late Summer of 2015 I bought a 52 Chevy Pickup that is basically stock. I am looking for a cosmetically good looking radio that does or does not have to work. The truck has a 12 volt system so I do not believe the original radio will work. I just want the radio for looks only. I posted my concerns in the classified section but I just wanted to air it here as well.
Rich
Retired Military, Six years Army, Seventeen years Air Force
Army Security Agency High Speed Morse Code Intercepter
Rigger C-130
Master Sergeant 32nd Aerial Port Squadron
Commander American Legion
Woj #1144587 01/14/2016 2:24 AM
You can use an original radio by using a resistor that costs less than $10. If you want one just for looks, try and buy an unrestored model and buy the dial lens, bezel, buttons and knobs new from one of the truck parts vendors.
1951 1 Ton Completed
Woj #1144595 01/14/2016 2:43 AM
Woj
Offline
Wow did not know about the resistor thing. If I could get one to work as well as looking good that would be the direction I would go. Where is the resistor located and how hard is it to replace?
Rigger C-130
Woj #1144598 01/14/2016 3:00 AM
You need a 1 ohm 50 watt resistor to connect in series with the radio 12 volt supply. Jim Carter lists it as an "EL135". He lists it for 19.95 but from an electronics store like Digi Key, they cost just under $5. Jim Carter Listing
Woj #1144902 01/16/2016 3:10 AM
Woj
Offline
I think I may look for a cosmetically good looking radio for dash looks and install a hidden modern system.
Rigger C-130
Moderated by  truckernix
