| | | Forums66 Topics128,014 Posts1,055,329 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 24 | I am new to Stovebolt and am in need for some advice. In late Summer of 2015 I bought a 52 Chevy Pickup that is basically stock. I am looking for a cosmetically good looking radio that does or does not have to work. The truck has a 12 volt system so I do not believe the original radio will work. I just want the radio for looks only. I posted my concerns in the classified section but I just wanted to air it here as well. Rich
Retired Military, Six years Army, Seventeen years Air Force Army Security Agency High Speed Morse Code Intercepter Rigger C-130 Master Sergeant 32nd Aerial Port Squadron Commander American Legion | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You can use an original radio by using a resistor that costs less than $10. If you want one just for looks, try and buy an unrestored model and buy the dial lens, bezel, buttons and knobs new from one of the truck parts vendors. | | | | | Joined: Dec 2015 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 24 | Wow did not know about the resistor thing. If I could get one to work as well as looking good that would be the direction I would go. Where is the resistor located and how hard is it to replace?
Retired Military, Six years Army, Seventeen years Air Force Army Security Agency High Speed Morse Code Intercepter Rigger C-130 Master Sergeant 32nd Aerial Port Squadron Commander American Legion | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | You need a 1 ohm 50 watt resistor to connect in series with the radio 12 volt supply. Jim Carter lists it as an "EL135". He lists it for 19.95 but from an electronics store like Digi Key, they cost just under $5. Jim Carter Listing
| | | | | Joined: Dec 2015 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 24 | I think I may look for a cosmetically good looking radio for dash looks and install a hidden modern system.
