1 members (Hotrod Lincoln), 41 guests, and 0 robots.
Topics128,035
Posts1,055,560
#114394 03/27/2003 12:49 AM
I do not claim to be a mechanic by any stretch of the imagination, but I do love old trucks. I own a '51 Chevy 3/4 ton pickup and am learning restoration as I go along. My '51 is geared very low and has trouble getting up any speed on the highway. What can I do to improve this? One person suggested changing rear ends. He said change the pumpkin. To me a pumpkin is something to make pies out of. Can someone set me staight? Thanks.
#114395 03/27/2003 1:23 AM
Junior Member
Junior Member
Scruffy,
What I have always called the pumkin is the cast iron center of the rear end that the two axle tubes come out of. but some people and I'm guessing this guy means the differential inside the rear end.the easiest way is to just swap out the entire rear end with a good one having the gearing you want. if you want your original rear end then its a gear swap.hope it helps
#114396 03/27/2003 1:34 AM
Switch your pumpkin for a cantaloupe and you will be good to go.
54 3100 with 235
62 flatbed dump C60 with 261
#114397 03/27/2003 2:37 AM
Scruffy, Click on this link on the Kook's Web Page...
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#114398 03/27/2003 3:34 AM
How the heck did I get my post in the rust forum? I better be more careful about which buttons I am pushing.
I have gotten a some great information about rear end swaps for my truck, everything from fruit to nuts.
#114399 03/27/2003 4:07 AM
I resemble that remark.
It sure seems to be a lotta trouble to end up with 4.11 while the half tonners have 4.11 and their trucks still only go 50mph. My 54 has 3.90 and I can't wait to upgrade to 3.55. It seems to me that if you go through all that much work you should at least get into the 3.73 range. This would require getting a donor rear end and some welding is involved.
54 3100 with 235
