| | | Forums66 Topics128,039 Posts1,055,591 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2003 Posts: 10 Member | | Member Joined: Feb 2003 Posts: 10 | I do not claim to be a mechanic by any stretch of the imagination, but I do love old trucks. I own a '51 Chevy 3/4 ton pickup and am learning restoration as I go along. My '51 is geared very low and has trouble getting up any speed on the highway. What can I do to improve this? One person suggested changing rear ends. He said change the pumpkin. To me a pumpkin is something to make pies out of. Can someone set me staight? Thanks. | | | | | Joined: Feb 2003 Posts: 33 Junior Member | | Junior Member Joined: Feb 2003 Posts: 33 | Scruffy, What I have always called the pumkin is the cast iron center of the rear end that the two axle tubes come out of. but some people and I'm guessing this guy means the differential inside the rear end.the easiest way is to just swap out the entire rear end with a good one having the gearing you want. if you want your original rear end then its a gear swap.hope it helps | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Switch your pumpkin for a cantaloupe and you will be good to go.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Scruffy, Click on this link on the Kook's Web Page...
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
| | | | | Joined: Feb 2003 Posts: 10 Member | | Member Joined: Feb 2003 Posts: 10 | How the heck did I get my post in the rust forum? I better be more careful about which buttons I am pushing. I have gotten a some great information about rear end swaps for my truck, everything from fruit to nuts. | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I resemble that remark.
It sure seems to be a lotta trouble to end up with 4.11 while the half tonners have 4.11 and their trucks still only go 50mph. My 54 has 3.90 and I can't wait to upgrade to 3.55. It seems to me that if you go through all that much work you should at least get into the 3.73 range. This would require getting a donor rear end and some welding is involved.
