Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Gdads51, Stewart2, Otto Skorzeny, 1 invisible), 85 guests, and 1 robot.
Topics128,292
Posts1,058,598
Members48,492
#1143870 01/09/2016 4:18 AM
I know all of you have dealt with the problem of needing one I.D. on one end and a different I.D. on the other end...and unless the vehicle came that way from the factory we are left to try and find one which usually ends up being a FLEX HOSE.
I'm in the need of a hose with 1 3/4 ID on one end and 1 1/2 ID on the other. In this case a bottom hose going from radiator to water pump.
However, I HATE FLEX HOSES.
My Question: Do any of you know where you can get what I call "hose shims". Sometime ago I have bought "universal radiators" and they came with a "shim" or "band" that you could use on the radiator or water pump neck, to make a hose fit.
In my case I'd use a 1 3/4 I.D. hose on both ends and use the shim/band/adapter piece on the end where the neck is 1 1/2".
Any of you guys know of a place that handles something like this? The local Flaps just look at me like I'm crazy. Anyone, Jerry?, DG?, Deve?, Dave?, Tim?, anyone?
(I can find one with the right bends)
Thanks for any insight.
I have had to do that before... I just cut off a piece of the correct size hose to use as a shim. Never had a problem with it.
1954 GMC 9314 - 261 t5
x2...
add a 2" long piece of 1-1/2" hose to the small fitting and slip the 1-3/4" hose over it...done!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
X3 Alvin,
Always works for Me!
regards,
steve sr.
Alvin, having gone this far with your project, have you thought
about having a radiator shop, if you can find one, solder a
matching fitting in the radiator?
dg
Denny G
Sandwich, IL
Alvin,
I got the GM stamped radiator hoses from Chevy's of the 40's. Ran into the same problem...needed 1 3/4 I.D. and the hose was 1 1/2" I.D. Went to Lowes and got a PVC 1 3/4 " O.D. fitting and with some persuasion with boiling water and silicone grease was able to stretch the end onto the PVC fitting. Let it set and cool. Removed the PVC fitting and now the hose fits the 1 3/4" radiator fitting. Just an idea.
Tim
1970 VW Beetle
I hear you guys.
I've been down this road a few times. I guess I'm just looking for the "easy way out" as it seems I do the older I get!
I have also used two hoses with a reducer/adapter in the middle to "get there". Again, looking for simply solutions but they get fewer and farther between.
We will get'r done.
I have access to a friendly NAPA store. The kind folks let us walk into the area with the hoses and compare the samples we took with us. I did find a shaped hose with the proper ends(big for the water pump and small for the radiator). And like the idiot I am forgot to keep the part number. But the good news is it fit. Must be a chart of hose some where? I will keep looking.
Steve H
