| | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | My 235 has some water that drips out of the exhaust when I first start the engine. It will leave a puddle about the size of a softball and you can see droplets clinging to the tailpipe and blowing out due to airflow. After it's up to temp it doesn't have any water or smoke out of exhaust. The oil looks clean with no signs of coolant and it doesn't seem to be losing any coolant. I do have a short tailpipe that turns out in front of the left rear tire, so there is no hump going over the rearend that could potentially trap any water buildup from making it out of the system. Is this a normal amount of water due to condensation from the cool exhaust system condensing moisture in the exhaust gases on startup, or do I need to start thinking bad thoughts? | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sounds normal to me, water or steam is a byproduct of combustion.
If it smelled like antifreeze that would be cause for alarm. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Excerpt for SLATE: "The carbon from the gasoline mixes with oxygen from the air. Gasoline consists mostly of hydrocarbons–chains of carbon encircled by atoms of hydrogen. When the hydrocarbons burn, they break apart and recombine with the air. This reaction produces heat, as well as two chemical byproducts: water and carbon dioxide." Complete article: http://www.slate.com/articles/news_and_politics/explainer/2006/11/how_gasoline_becomes_co2.html dg
Denny G Sandwich, IL
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Another possible cause, also under the 'normal' banner, is condensation in the muffler. When you shut off a hot engine and the exhaust system cools, moisture condenses inside the muffler and low areas of the pipe. That's what causes your muffler and piping to rust over time. When you start it up again the rush of exhaust gasses blows some of the water out the end of the pipe. That moisture boiling off is what causes the mist/fog/steam that comes out the tail pipe in cold weather.
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Byproduct of combustion is condensation (water). Basic combustion theory 101-
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I had a customer years ago saw water coming out the tail pipe like that. He started cussing the gas station saying they put water in the gas. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | The better tuned/more efficient the engine is running, the more water is produced. If the muffler isn't stainless and doesn't have a drain hole, I always drill a 1/16-3/32 hole in the bottom lowest edge to let the condensation out. Mufflers last a lot longer. | | | | | Joined: Mar 2010 Posts: 10,310 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,310 | I have seen brand new cars with water pouring out like a leaky faucet.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is 1 gallon of water produced by using 1 gallon of gas. Most of it comes out as vapor. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Depending on temperature the amounts of "water" will vary. If I start an engine up I always let it run until its up to temperature and let it run for a little. This heats up the exhaust system and dispenses of a lot of the moisture. Otherwise, an engine that runs just for a little not only "sweats" in the exhaust system but also in the engine.
....once tore down an engine where a lady only drove it to work which was 2 miles. You should have seen the "brown milky" stuff that was in that engine and accumulated over the years.
If you gonna start it up....let it get hot. | | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | Thanks for all the responses. I know water is a byproduct of internal combustion, I was just concerned that there was a bit too much water in this case. Some of the responses make me feel a little more comfortable now though. I'll see how it goes this coming summer! | | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Taste it, if it is sweet you might have a coolant leak.
| | | | | Joined: Jan 2015 Posts: 192 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 192 | I'll pass on that taste test:) | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | My old wind broke 49 216 has all kinds of stuff blowing out when I 1st start it up, especially when it's cold out.
Oil, soot, condensation, water and vapor, it looks like it's doing #1 and #2 simultaneously LOL. Then once it warms up theres hardly a wisp of anything, except the slight smell of oil burning.... I don't mind it as it keeps the tail gaters back.
As said, it's probably just condensation and the byproducts of combustion. But keep an eye on your coolant level just in case.
Dave | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | you see water dripping from any/every car on cold mornings. At least I have seen it. My truck usually has a little puddle that has dripped out when it first starts, my new cars as well. But that doesn't necessarily preclude some other problem, particularly if it is green.... | | |
