1 members (Hotrod Lincoln), 61 guests, and 2 robots.
Topics128,049
Posts1,055,740
#1140560 12/21/2015 11:38 PM
I have a 1958 Apache and the wiper switch failed. I bought one from LMC and it is totally different than old switch has 2 terminals new one has 4,looks like bat,low, high,and park any thoughts on how to wire this?
Big Bolt Forum Moderator
good luck! I do not believe they make an exact replacement. I have pulled 2 apart and cleaned the contacts and then put them back together (had to epoxy the back on though). I did buy one out of a 64-88 truck, it also has the washer terminal on it. You could drill the center if you knob out if it is solid (some just had a rubber plug in them). I believe the internals of the switch are fine, but it fits in a bigger hole so, you will have to file out the hole in your dash and bezel nut and then find another small thin nut to hold it on with. Chevy part # is 1993641. Here is a link to one on Ebay.
http://www.ebay.com/sch/i.html?_fro...93641.TRS5&_nkw=1993641&_sacat=0
Mike
Thanks Cuda for the tip will give it a try!
