5 members (55shaker, Phak1, TUTS 59, Otto Skorzeny, Wayne67vert), 119 guests, and 0 robots.
Topics128,095
Posts1,056,069
Members48,433
#1134291 11/14/2015 5:09 PM
Hey fellow Burb owners, anyone know of a source for the trim metal around the perimiter of the plywood floor? The angled trim on the sides front to back around the wheel wells? Mine is badly rusted in some sections. It is a 1952 GMC. Or what have you done to replace them? Much thanks from sunny Arizona.
~ Richard
1952 GMC Army Ambulance
"Building the Dream"
The story begins here in the DITY Gallery
Follow the build in the Project Journals
(If you can't wait, the "final pictures" and details are in Panels & Burbs)
First vehicle-1967 Chevy short bed pickup. Sold when got married frown | 1953 Chevy pickup restored-sold to purchase Toy Hauler trailer | 1964 GMC long bed Pickup 305 big block V/6 bought to restore with son and his 14 yr old son
Welcome to Stovebolt.com, azcornman
Please include the year of your truck in all posts. That allows readers to be certain their reply is referring to the correct vehicle.
No replies.? Speaking with a guy this weekend at the Goodguys show in Scottsdale, was trying to sell a 1 ton long body 53 panel. He told me the trim I'm asking about is welded to the inner body panels. Plywood floor is sandwiched between trim and floor with the carriage bolts through all. Is that so? Has anyone addressed the rusted out trim pieces? Made your own? I'm thinking carpet with the edges bound then stainless flat of some kind to hold it down. Would really like to see what some have done!
~ Richard
Sorry I won't be of much help. Mine are in good/restorable shape.
mine is a panel so not sure mine is like yours but mine is a one piece of ply wood and has a metal "strip" around the edges but it is not "removalable" as one piece. Let us all know what you find out, or how you handle this. I'm curious.
That "lip" is welded on.
No one makes a replacement.
You will have to fabricate a replacement strip or remove one from another 47-55 Suburban.
There are 20+ spotwelds on each side.
Well, it sounds like I'm in for some more work. Thanks for the replies guys! It sat too long without glass and rain and snow did its work on a lot of the trim. Wood is fine. I will post when I get to that stage. Thanks again.
~ Richard
go to a sheet metal shop ,and have some flat say 16?? gauge strips bent into a 90 degree angle, go to harbor freight and buy a "shrinker-stretcher" unit and this will shrink the angle to fit the corners to the body ! if you have not seen one work ?go to "metelmeet .com or "all metalshaping .com lots of info on there ! good luck
Currently cruising
in the
Passing Lane
The angle pcs. You're talking about is in fact, spot welded to the inner side panels. The ones that are on a panel is the same as a burb. Im working on them right now.if you can find a panel truck with good ones, you can cut out the spot welds and reuse them on your burb. Where in Az. Are you? I'm near Surprise, Az.. Do you have the one piece plywood floor? Are you replacing that too?
