| | | Forums66 Topics128,014 Posts1,055,332 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 236 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 236 | Hey Guys, I'll be painting my 51, 235 in the next week or so. Should I prime the engine first? Or, is the roughness of the egine enough? This is probably a dumb question but, I have never painted an engine before. I'm going to spray it with paint from Jim Carters.
Glenn, | | | | | Joined: Feb 2003 Posts: 33 Junior Member | | Junior Member Joined: Feb 2003 Posts: 33 | I always prime mine first,the paint will stick ok if you dont but the color comes out a lot nicer if you prime it,its kind of hard to cover the dark cast iron without priming first. | | | | | Joined: Mar 2004 Posts: 4 Junior Member | | Junior Member Joined: Mar 2004 Posts: 4 | Depends how long you want it to last. I would prime it just to get even colorcoverage. It'll last longer with primer. Paint itself actually doesn't stick to bare metal all that well. Especially Cast Iron.
Where's this go?
| | | | | Joined: Apr 2002 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2002 Posts: 42 | Do I need a special high heat primer? If so, any reccomendations? thanaks wjb | | |
