8 members (FrankenChevy, fonz8261, Peggy M, baldeagle, tclederman, TexasJim50, carbking, 1 invisible), 52 guests, and 4 robots.
Topics128,018
Posts1,055,341
Members48,419
#114202 04/10/2004 11:30 PM
Hey Guys,
I'll be painting my 51, 235 in the next week or so. Should I prime the engine first? Or, is the roughness of the egine enough? This is probably a dumb question but, I have never painted an engine before. I'm going to spray it with paint from Jim Carters.
Glenn,
Scootin thru with a 52,
Good, Economic and Classic
1952 Chevy 1/2-Ton
#114203 04/11/2004 1:05 AM
Junior Member
Junior Member
I always prime mine first,the paint will stick ok if you dont but the color comes out a lot nicer if you prime it,its kind of hard to cover the dark cast iron without priming first.
#114204 04/11/2004 10:51 AM
Junior Member
Junior Member
Depends how long you want it to last. I would prime it just to get even colorcoverage. It'll last longer with primer. Paint itself actually doesn't stick to bare metal all that well. Especially Cast Iron.
Where's this go?
#114205 04/22/2004 11:08 PM
Do I need a special high heat primer? If so, any reccomendations? thanaks wjb
