7 members (Bill Hanlon, Otto Skorzeny, 52Carl, Hotrod Lincoln, TooMany2count, chemanic, 1 invisible),
92
Mod | | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | I was talking with a guy the other day about his parts trucks. He told me had a 1956 V8 truck that came from the factory with a 265 engine with power pack heads. He had just sold the engine and transmission. I asked if the plate that covers the hole where the foot stomp went still in the truck. He told me it had a foot stomp, so the plate wasn't there. I told him I'd wasn't aware of any V8 trucks having foot stomp starters. He assured me it came from the factory that way. Of course I was skeptical and asked if he was sure about that. He told me he was the 3rd owner and knew both previous owners. The original owner worked for GM and had ordered it that way. Is anyone aware of another factory V8 truck having a foot stomp or is this a one of a kind?
1959 3100 Apache Fleetside
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I wonder if that was a special order or an RPO? | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | I just went out and looked at my '56 265 and see that the draft tube would be in the way of linkage if a foot stomp was used. I also looked through my Data Books and did not see an RPO for it... I'm not saying it can't be done, I just don't think the factory ever did it... Mike B  | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | It seems to me it would be almost impossible. If I can get contact info on the original owner, I'll try to find out how he got the truck with a 265 and foot stomp starter.
| | | | | Joined: Feb 2004 Posts: 29,817 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,817 | I've seen a fake foot stomp pedal mounted to a heavy duty starter switch like the one used on some farm tractors. It just energizes the starter solenoid electrically but the pedal and rubber bellows from a stomper is adapted to the switch.
| | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | I've seen a fake foot stomp pedal mounted to a heavy duty starter switch like the one used on some farm tractors. It just energizes the starter solenoid electrically but the pedal and rubber bellows from a stomper is adapted to the switch. Somebody else here just did that! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I was talking with a guy the other day about his parts trucks. He told me had a 1956 V8 truck that came from the factory with a 265 engine with power pack heads. He had just sold the engine and transmission. I asked if the plate that covers the hole where the foot stomp went still in the truck. He told me it had a foot stomp, so the plate wasn't there. I told him I'd wasn't aware of any V8 trucks having foot stomp starters. He assured me it came from the factory that way. Of course I was skeptical and asked if he was sure about that. He told me he was the 3rd owner and knew both previous owners. The original owner worked for GM and had ordered it that way. Is anyone aware of another factory V8 truck having a foot stomp or is this a one of a kind? Either he's pulling your chain to see if you'll believe him, or he simply has no clue what he's talking about himself. No V8 trucks left the factory with a stomp starter. Same goes for inline 6 trucks with the Hydramatic and RHD export trucks. I would also call him on the truck having "Power Pak" heads.
Bill Burmeister | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | I do know power pack heads were not in existence in 56, esp for a 265. I think they could have been added later. I'm not even sure I can even see the truck now, I've been calling him ever since to set up a day/time to come look at his parts, but he's not answering. He is advertising a '58 project for sale for $13k tho.
| | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | '56 Power pack heads, '56 V8 stomp starter, $13K for a '58 "project"? RUN FORREST, RUN!
| | | | | Joined: Feb 2004 Posts: 29,817 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,817 | Actually, the 265 Corvette with the 2-4BBL option had a set of high compression heads available, but they didn't have the classic triangle-shaped casting mark associated with the later model powerpack head. I believe it was a single, narrow rectangle above the squared-off pad at both ends of the head. There was another head with two narrow rectangles which was also used on one of the high performance 265's. These heads were very low-production items, and other than for a numbers-matching restoration, there are much better performance choices available. Jerry
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | I finally got him to call me tonight. I'm going to visit him and maybe get some parts.
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | I went to see the guy today and got some good parts and also saw the truck and motor. The truck was an original 6 cyl truck that the original owner put a 265 in. It did not have a V8 stomp starter setup. There was no linkage on the bellhousing. The engine did have power pack heads, but I couldn't tell what the casting or date code numbers were as the valve covers were still on it and it was wrapped in shrink wrap. It had a 4 bbl carb on it, so I guess it could be a power pack engine. The crossmember V8 brackets were added on using carriage bolts and not the factory rivets. After talking to him, it appears he was confused about what was original to the truck.
The 58 project truck is about 70% done and looked to be a Cameo. It has a cameo bed on it, but I didn't see the VIN to be able to determine it to be an original cameo. he told me the bed was reproduction, so I'm leaning to it NOT being a Cameo. It has a 350 engine, Camaro rearend, later model steering column, bucket syle seats
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Allot can happen in the 60 year life of our trucks making it hard to know what's really original and what's not... Mike B  | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I went to see the guy today and got some good parts and also saw the truck and motor. The truck was an original 6 cyl truck that the original owner put a 265 in. It did not have a V8 stomp starter setup. There was no linkage on the bellhousing. The engine did have power pack heads, but I couldn't tell what the casting or date code numbers were as the valve covers were still on it and it was wrapped in shrink wrap. It had a 4 bbl carb on it, so I guess it could be a power pack engine. The crossmember V8 brackets were added on using carriage bolts and not the factory rivets. After talking to him, it appears he was confused about what was original to the truck.
The 58 project truck is about 70% done and looked to be a Cameo. It has a cameo bed on it, but I didn't see the VIN to be able to determine it to be an original cameo. he told me the bed was reproduction, so I'm leaning to it NOT being a Cameo. It has a 350 engine, Camaro rearend, later model steering column, bucket syle seats V8 with Power Pak heads and 4bbl carb would have come out either a Passenger car or Corvette, they were never offered in a light Truck (4bbl carb was an option on heavy duty 2 ton and larger, though). On the '58, unfortunately, they did not include anything in the serial numbers to differentiate the Cameo from any other truck. As you mention, reproduction beds are available, so it very well could be a conversion.
