4 members (Wayne67vert, Southerntruck, Guitplayer, Napco Man), 106 guests, and 2 robots.
Topics128,093
Posts1,056,477
Members48,444
Disassembled rockers for cleaning, reassembled and set valves,started truck all good but not much oil to the rockers ( plenty coming past)
The only part of reinstall that I was a bit hazy on was the oiler fitting between the two rocker shafts.
The oiler fitting consists of the fitting itself a cap like restrictor and a spring.
I put the spring in the left side of the oiler fitting followed by the cap facing in
Is this correct?
Thanks and Merry Christmas
Thanks Tim
It doesn't mention the cap / cup type ristriction fitting
This is the part that im not sure on
Cup facing in or out?
Ex Hall Monitor
Ex Hall Monitor
