Disassembled rockers for cleaning, reassembled and set valves,started truck all good but not much oil to the rockers ( plenty coming past)
The only part of reinstall that I was a bit hazy on was the oiler fitting between the two rocker shafts.
The oiler fitting consists of the fitting itself a cap like restrictor and a spring.
I put the spring in the left side of the oiler fitting followed by the cap facing in
Is this correct?
Thanks and Merry Christmas
