| | | Forums66 Topics128,105 Posts1,056,545 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | Disassembled rockers for cleaning, reassembled and set valves,started truck all good but not much oil to the rockers ( plenty coming past) The only part of reinstall that I was a bit hazy on was the oiler fitting between the two rocker shafts. The oiler fitting consists of the fitting itself a cap like restrictor and a spring. I put the spring in the left side of the oiler fitting followed by the cap facing in Is this correct? Thanks and Merry Christmas
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | Thanks Tim It doesn't mention the cap / cup type ristriction fitting This is the part that im not sure on Cup facing in or out?
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 |
