0 members (), 149 guests, and 2 robots.
Topics128,113
Posts1,056,619
Members48,450
Hi-
I just adopted a decent '63 and the column shifter won't cooperate...it won't go into reverse.
It goes in 1st and second.
Any tricks I should know before diving into this linkage???
Ron Albany, NY
Disconnect the linkage and move the arms on the transmission into reverse. If it goes in easily, start the truck and see if it moves in reverse. If that works, it's most likely a worn bushing. You can try jiggling the linkage and then try going to reverse. I remember a '63 we used to have doing the same thing. I'd jiggle the linkage and away I'd go. It was a worn bushing.
1959 3100 Apache Fleetside
i just fixed this on my 65. i'm not sure about the linkage on your 63 but check out this video to see if it will help.
jeff
Does it have overdrive? You can't put it in reverse with overdrive engaged. This can happen if the PO wired up the linkage and disconnected the governor and added a switch somewhere like the bottom edge of the dash.
1959 Fleetside Apache Deluxe Shortbed
For what it is worth I just picked up a 63' and one of my first projects is squaring away the TOTT. I have some photos from a guy named Jay of his tear down I can share. I have some pics of my basic adjustment attempt on my Flickr site. The three links below from another forum site and on a youtube video on a later model.
http://67-72chevytrucks.com/vboard/showthread.php?t=215307
http://67-72chevytrucks.com/vboard/showthread.php?t=256851
http://67-72chevytrucks.com/vboard/showthread.php?t=452809
Not sure if you resolved the issue but the closest thread to date. Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
