3 members (texas46, Otto Skorzeny, 55shaker), 178 guests, and 0 robots.
Topics128,100
Posts1,056,178
Members48,436
#1140901 12/24/2015 2:03 AM
Take it to a shop or do-it-yourself? I always took it to a shop but thinking of trying it myself. This is an open driveshaft on a '53 1-ton.
1953 GMC 1-Ton Pickup with 350 and 700R4
Can you get it straight- - - -like less than .005" runout and less than 1 degree phase angle error of the yokes? If so, go for it! I build my driveshafts in a lathe with a center rest, a machinist's level, and a dial indicator.
Without a lathe, I would never attempt it. Although it doesn't turn that fast, getting it in balance and aligned correctly would be difficult.
Sir Searchalot
Sir Searchalot
Not a DIY even if you have a lathe. It is not that expensive. Let them cut, weld, balance.
We used to do it on school buses when the yokes would get damaged. Marking it before cutting really helps the alignment when going back together. Chop saw, welder, and straight edge is all we used. A friend of mine welded wider rims to his Pontiac wheels center section using only an indicator to align them while spinning the axle. It's just as crude as welding a driveline, but they turned out true and have run over 140 mph.
Joe
Not true KL, that drive shaft in a straight 1:1 transmission is
gonna turn the same RPM as the engine is turning. In a stock
Stovebolt that's not much more than 3,000 rpm but if your hot
rodding it it's gonna see a lot more.
Besides the alignment challenge, you've got no way to balance
it.
dg
Denny G
Sandwich, IL
....its amazing how many "home repaired" drive shafts we have to fix at Carolina Driveline, and many from shops who have the tools but found its better we do it.
http://carolinadriveline.com/ you'll even see a shot of my truck and panel if you click on Restoration under Product Line Up smile
Unless you have the equipment to do it right the first time save yourself a lot of trouble and let a shop cut and balance it.
it.
dg
I was talking in relative terms on RPM, thinking the OP was putting it behind a stock engine. A stovebolt and a high revving V8 are different animals for sure. Only with an OD tranny will the driveshaft turn faster than the engine.
I've had a pretty fair success rate balancing a driveshaft by clamping a 1/2 oz. wheel weight to the shaft at one end or the other with a big hose clamp, and test driving the vehicle. The floorboard and seat makes a pretty good monitor of vibration. Move the weight around the shaft in 1-inch increments until the sweet spot is found, then tack weld a steel washer or two in that position for a permanent fix.
