1 members (MikeE), 121 guests, and 2 robots.
Topics128,129
Posts1,056,360
Members48,441
Hi again,
When I bought this project truck, the owner told me the engine was running when the manifolds were taken off. I am in the process of rebuilding and just got to the distributor, but I am not sure it is correct for the engine. I don't want to screw up a freshly rebuilt engine so I would appreciate your help with this.
The dizzy is a Delco Remy Model - 1112353 with S/N - OC25
help!!!!!!
1112353 is from a 1949-50 216 engine.
I THINK a 54/235 should have a 1112388...someone here posted a sheet showing the numbers for years 29-62. I printed it out but don't have a link to it. It may even be in the Tech Tips?
Distributor numbers by year.
I would confirm which cam material you have first Gear ID.
My Blog
Thanks guys, through the machine shop I have a new cam with what I can only imagine would be steel.
Also, Dave, the page at your link says I should have a "short cap", but the one I have appears normal. So I guess my question is, will this distributor work for a 235?
Thanks!!
It is only important that gears match, steel distributor gear to steel cam, or cast distributor gear to cast cam.
Chevrolet does say that a cast distributor gear can be used on a steel cam.
My Blog
I would go with a gm HEI ..I put one in my 46 1/2 ton when I rebuilt the motor and have no problems at all...speedway motors sells them.....it also eliminates the use for a coil, and I have a 1956 235 in my truck
