| | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2015 Posts: 47 | Hi again, When I bought this project truck, the owner told me the engine was running when the manifolds were taken off. I am in the process of rebuilding and just got to the distributor, but I am not sure it is correct for the engine. I don't want to screw up a freshly rebuilt engine so I would appreciate your help with this.
The dizzy is a Delco Remy Model - 1112353 with S/N - OC25
help!!!!!! | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 1112353 is from a 1949-50 216 engine.
I THINK a 54/235 should have a 1112388...someone here posted a sheet showing the numbers for years 29-62. I printed it out but don't have a link to it. It may even be in the Tech Tips?
| | | | | Joined: May 2015 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2015 Posts: 47 | Thanks guys, through the machine shop I have a new cam with what I can only imagine would be steel.
Also, Dave, the page at your link says I should have a "short cap", but the one I have appears normal. So I guess my question is, will this distributor work for a 235?
Thanks!! | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | It is only important that gears match, steel distributor gear to steel cam, or cast distributor gear to cast cam. Chevrolet does say that a cast distributor gear can be used on a steel cam.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I would go with a gm HEI ..I put one in my 46 1/2 ton when I rebuilt the motor and have no problems at all...speedway motors sells them.....it also eliminates the use for a coil, and I have a 1956 235 in my truck
