0 members (), 35 guests, and 3 robots.
Topics128,014
Posts1,055,327
Members48,419
#1140413 12/21/2015 1:55 AM
I have a 250 six installed in my 50 chev AD the fan sits too low and has some cooling issues .. is there a way to move the water pump or just the fan blades to centre it on the rad?
Fast Fredy #1140421 12/21/2015 2:48 AM
I have not developed an adapter plate for those engines, but I would think the adapter design I sell for 235's could be made for those engines.
Here is some info on the 235 adapter.
My Blog
Fast Fredy #1141109 12/25/2015 2:02 AM
I had a similar issue with a 350 install. I modified the original radiator support (measure/cut/weld/remeasure/re-cut/re-weld) to allow me to lower the radiator. My issue was more related to making clearance for the fan blade and auto-transmission/radiator coolant lines, but also put the fan in the right place.
Carl
Fast Fredy #1141113 12/25/2015 2:26 AM
Fast Fredy, you are not alone with your problem which is an often repeated problem here. Electric fans have come a long way and today is on most all cars. With the reliability proven on them I'd recommend going to a junk yard and finding one that will work on your truck.
....but, to save gas, time, and a few 4 letter words, buy a GOOD electric fan with the temp control to kick it on and off and you'll never be sorry. I learned my lesson the hard way.
Fast Fredy #1141170 12/25/2015 3:15 PM
Wire it "hot" with the key only, so it doesn't run your battery down when you park it.
