0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | I have reproduced sun visors and brackets. I covered the visors with the same leather as my seats. My problem is that the visors will not stay up. I pinched the metal sleeves but that didn't help. Any other suggestions?
b51r
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | I may be wrong, but if I understand correctly I THINK the rod has a place that is pinched near where the mounting screws are and is what makes the visor tight to flip up or down when the visor is slide on the rod. Wish I had a pic to explain. Did you put a "PINCH" on the Rod its self? | | | | | Joined: Nov 2010 Posts: 339 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 339 | You need to bend the rod a little to put tension on the visor to make it stay up. root | | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | I pinched the visor. has a metal sleeve
b51r
| | | | | Joined: Oct 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 55 | the visor is rotating around the rod b51r
b51r
| | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | As mentioned, if you put a slight arc in the rod, it will create a tension to hold it a little stiffer in the sleeve that is built in to the visor. | | |
