2 members (gswbbc, wilbur53), 139 guests, and 3 robots.
Topics128,035
Posts1,055,446
Members48,422
#1140046 12/18/2015 6:45 PM
I have reproduced sun visors and brackets. I covered the visors with the same leather as my seats. My problem is that the visors will not stay up. I pinched the metal sleeves but that didn't help. Any other suggestions?
b51r
b51r #1140080 12/19/2015 12:49 AM
I may be wrong, but if I understand correctly I THINK the rod has a place that is pinched near where the mounting screws are and is what makes the visor tight to flip up or down when the visor is slide on the rod. Wish I had a pic to explain.
Did you put a "PINCH" on the Rod its self?
b51r #1140091 12/19/2015 1:50 AM
You need to bend the rod a little to put tension on the visor to make it stay up. root
I pinched the visor. has a metal sleeve
b51r
the visor is rotating around the rod
b51r
b51r
b51r #1140359 12/20/2015 7:04 PM
As mentioned, if you put a slight arc in the rod, it will create a tension to hold it a little stiffer in the sleeve that is built in to the visor.
Moderated by  ndkid275, Phak1
